What will i need for a 92 integra ls swap into 92EG?
Old Feb 13, 2005 | 10:09 PM
gaydm's Avatar
Default What will i need for a 92 integra ls swap into 92EG?
hey, what do i need if i put a 92 ls motor in a 92 eg Hatch? can i use the stock motor mounts? etc..? thanks!
Also whats the difference between the 94+ ls motor and 92ls. and which one is better to put in a eg?
Modified by aznxredEG at 11:24 PM 2/13/2005
Old Feb 13, 2005 | 10:10 PM
A.E Motoring's Avatar
Default Re: What will i need for a 92 integra ls swap into 92EG? (aznxredEG)
http://www.hmotorsonline.com
look here for the whole LS swap...thats what u will need...this thread will prolly get locked.
Old Feb 13, 2005 | 11:00 PM
B16aDasher's Avatar
change tranny
Old Feb 14, 2005 | 12:01 AM
ZeRo AsSault's Avatar
I'm pretty sure the 94 ls tranny has slightly longer gears, which I'd recommend to use
Old Feb 14, 2005 | 12:12 AM
mikehawkBUiLT's Avatar
Default Re: (ZeRo AsSault)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZeRo AsSault &raquo;</TD></TR><TR><TD CLASS="quote">I'm pretty sure the 94 ls tranny has slightly longer gears, which I'd recommend to use</TD></TR></TABLE>
did i miss something here?
the ideal thing to do is get a shorter geared tranny which is what everyone else, except this guy, will recommend to use.
but as said above. hmotorsonline.com have complete swaps and come with everything you need except mounts i think
check out this thread, it'll be pretty helpful
https://honda-tech.com/zerothread?id=878010
Old Feb 14, 2005 | 12:35 AM
Mischief_EG's Avatar
Default Re: (emo-ejcoupe1.6)
you can use the stock main tranny mount and rear firewall mount. you have to use an integra main driverside mount, and integra ac torque bracket and tranny torque bracket. you can use either civic or integra ac and tranny torque bracket mounts. you can even use your stock throttle cable, but its recommended to switch to a b series cable. hope this helps with the mount part of the swap, good luck!
Old Feb 14, 2005 | 07:59 PM
gaydm's Avatar
Default Re: (Team_MISCHIEF_916)
thanks
mattyfo0z
26
May 14, 2008 10:14 AM
grnteg98
Oct 19, 2006 07:10 AM
Turbo Squid
Nov 2, 2005 06:58 PM
onetwothree
Jan 1, 2004 06:00 PM
