1st gen integra motor (1.6 dohc) and ZC
Old Jan 17, 2002 | 10:54 AM
AmauryR's Avatar
Default 1st gen integra motor (1.6 dohc) and ZC
Hey, whats up, a buddy of mine's gonna swap a 89 integra dohc engine into his 86 cr-x Si. now I heard the ZC and his D16a-something are very similar, can the cams for the ZC be used in his motor? Also since the '89 teg motor is a D-series, can pistons (aftermarket) for a newer d-series fit? Basically, I wanna know what are the possible mods that can be done with the engine he has. Thanks.
Old Jan 17, 2002 | 11:15 AM
Redline130's Avatar
Default Re: 1st gen integra motor (1.6 dohc) and ZC (SKiLLz-R)
The ZC cams will bolt into the D16A1. I'm not too sure that SOHC pistons will work with the DOHC head. I believe the valve cuts on the SOHC pistons are different from the ZC/Teg pistons. The bore sizes of both motors are the same though. HTH
Old Jan 17, 2002 | 11:19 AM
AmauryR's Avatar
Default Re: 1st gen integra motor (cyber13)
thanks, I'll pass the info on. does any1 make camgears for the engine? also I heard about using old CR-X hf crank pulley cuz its lighter. Any other tips would b helpful, thanks a lot.
Old Jan 17, 2002 | 03:07 PM
B17CR-X's Avatar
Default Re: 1st gen integra motor (SKiLLz-R)
AEM makes cam gears for the D16A1 (86-89) teggy motor...
-Joel
Old Jan 17, 2002 | 03:12 PM
Hondasaurs's Avatar
the 89 integra is a 1st gen (olive vavle cover) ZC... it only has 108 hp ...he is better off getting a 2nd gen (black vavle cover) ZC
Old Jan 17, 2002 | 04:49 PM
rpr's Avatar
rpr
Default Re: 1st gen integra motor (ZC_CRX)
Bzzzt. Wrong.
86-87 USDM Teg -> D16A1 Olive/Brown 113hp 1.6l DOHC
88-89 USDM Teg -> D16A1 Black 118hp 1.6l DOHC
88-91 JDM Civic/CRX -> ZC Olive/Brown 130hp 1.6l DOHC
I believe there is a black top JDM ZC 1.6l DOHC, but I'm not sure what it came in.
Old Jan 17, 2002 | 05:00 PM
wronghand's Avatar
The only one major problem with putting a 2nd generation ZC in a 1st generation crx. The 2nd generation ZC uses different motor mounts. In fact you have to modify one of the mounts on the integra (D16A1) motor to make it work. Here is a very good article about the swap:
http://hybrid.honda-perf.org/tech/3gtech.html
The D16A1 is also rated at about 118 hp rather than 108 of the 1st gen ZC (olive vavle cover).
[Modified by wronghand, 9:01 PM 1/17/2002]
temporarysuicide
Oct 31, 2006 12:48 PM
djphonics
Apr 18, 2006 07:28 AM
m_mathers_69
Jun 13, 2004 04:37 PM
86CRXSi
Jun 4, 2002 08:10 AM
v-tec crx
Dec 5, 2001 02:36 PM
