New Azenis Tire
Vulcan Tire site says that the 205/50/15 will be available in late March. They are taking pre-orders. Other sizes available at different times.
http://www.vulcantire.com/azenis_rt615_t.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr#xxxxlives »</TD></TR><TR><TD CLASS="quote">392$$ for 4 205 40 16's
Smaller than stock diameter, pro's and cons w/ that setup
</TD></TR></TABLE>Smaller than stock diameter, pro's and cons w/ that setup
This is off of the old SEMA brochure
Q1 2005:
195/60R14 86H
205/50R15 89W RF
225/50R15 91H
205/40R16 83W RF
205/40R17 84W RF
215/40R17 87W RF
255/40R17 94W
275/40R17 98W
225/45R17 94W RF
245/45R17 99W RF
Q3 2005:
185/60R14 82H
195/50R15 82H
235/40R17 87W
hope that helps...I didn't bother to list the 18 incher sizes but I guess I'll do it if someone requests for it.
Q1 2005:
195/60R14 86H
205/50R15 89W RF
225/50R15 91H
205/40R16 83W RF
205/40R17 84W RF
215/40R17 87W RF
255/40R17 94W
275/40R17 98W
225/45R17 94W RF
245/45R17 99W RF
Q3 2005:
185/60R14 82H
195/50R15 82H
235/40R17 87W
http://rt615.com might want to bookmark the site; Falken just launched it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless RB26 »</TD></TR><TR><TD CLASS="quote">oooooo... likey.
255/40 17's
Likey for what? What'd you do, buy some super car we don't know about?
255/40 17's
</TD></TR></TABLE>Likey for what? What'd you do, buy some super car we don't know about?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by THEINTEGRATION »</TD></TR><TR><TD CLASS="quote">
205/50R15 89W RF
225/50R15 91H
If your car's height adjustable for the slight difference, 225-50-15 might be an economical alternative for putting more tread on the ground.
If the new tyre's sidewalls are as still as the old tyre's, I don't think you'd have to worry about the extra sidewall height as long as you can get the car down to make up for the slight difference.
IMHO, of course.
205/50R15 89W RF
225/50R15 91H
IMHO, of course.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">225-50-15 might be an economical alternative for putting more tread on the ground.</TD></TR></TABLE>
Wider tread. Not more tread, just wider tread.
As for being economical, Vulcan is not yet posting prices for the 225, so we will just have to wait and see. (The price of the 205 size is 35 percent more than the same size in the older RT-215, but is still quite reasonable compared to many other top-performing tires.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by George Knighton »</TD></TR><TR><TD CLASS="quote">If your car's height adjustable for the slight difference
If the new tyre's sidewalls are as still as the old tyre's, I don't think you'd have to worry about the extra sidewall height as long as you can get the car down to make up for the slight difference.</TD></TR></TABLE>
The sidewall height on the 225/50-15 size is only 0.2 inch higher than stock - about the same amount by which the sidewall height of a stock size tire is taller than a 205/50-15 tire should be. I doubt that that small a difference in sidewall height is all that critical. If the 225 size rubs - I haven't tried it, and don't know whether it does or doesn't, but if it does - I would suspect it would be more due to the tread being 20 mm (0.8 inch) wider than the sidewall height being 0.2 inch taller.
These sidewall height figures assume, of course, that the size for the new RT-615 is similar to other brands/models of tires of the same nominal size. With the older RT-215, we have found that that assumption is NOT valid (at least, not for the 205/50-15). With the RT-615, again, we will have to wait and see.
yes, it will be interesting to see if the new 205 width will be the same as the old style 205 width (which we all know was not 205), or have they started producing tires more in line with the other brands width sizes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Stealth 95 GS-R »</TD></TR><TR><TD CLASS="quote">I'm curious too, I was reading about it not 2 seconds ago on Falken's site.</TD></TR></TABLE>
WELCOME TO LAST WEEK ANDREW
https://honda-tech.com/zerothread?id=1137092
Likey for what? What'd you do, buy some super car we don't know about?</TD></TR></TABLE>
My car is in my sig.
What'd I do? I did my research and decided that 245/45's will give me exactly what I'm looking for. Working with a large tire inventory everyday certainly helps me there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nemesis0104 »</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1137092 </TD></TR></TABLE>
sorry I don't live on H-T, Tony.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtasy »</TD></TR><TR><TD CLASS="quote">
I doubt that that small a difference in sidewall height is all that critical. If the 225 size rubs - I haven't tried it, and don't know whether it does or doesn't, but if it does - I would suspect it would be more due to the tread being 20 mm (0.8 inch) wider than the sidewall height being 0.2 inch taller.</TD></TR></TABLE>
I've evidently failed to express myself correctly again.
I wasn't worried about rubbing, but referring to the Honda Challenge racer's obsession with sidewall height. If the car is 1/4" higher than it would be with 205-50-15 or 225-45-15, then he is going to lower the car that 1/4", guaranteed.
It seems to me (on the east coast, anyway) that the other drivers tend to follow their lead.
On a DC2 ITR with a reasonable chassis height and reasonable wheel offset yes, you're right, 225 section tyres fit just fine. Some of us would have to roll the rear fender lips, but we also (some of us) have to do that with +38 using R comp 205's, so it's not anathema.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless RB26 »</TD></TR><TR><TD CLASS="quote">] I did my research and decided that 245/45's will give me exactly what I'm looking for. Working with a large tire inventory everyday certainly helps me there.
I'm jealous that your budget is greater than mine, that's all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RGoose18 »</TD></TR><TR><TD CLASS="quote">205/40/16
Smaller than stock diameter, pro's and cons w/ that setup</TD></TR></TABLE>
# wise yes, but knowing how Azenis were always bigger than stated it probably wouldn't be a problem
Jack Black
Nov 23, 2006 09:54 PM
