DA exhaust on EFs?
Old Feb 13, 2005 | 07:26 PM
Default DA exhaust on EFs?
I wanted to search this,but cant search "da"...only two words
I've gotten mixed responses to this question,was curious if anyone knew for sure,if a DA exhaust could fit a crx or be easily modified to do so
Old Feb 25, 2005 | 09:28 AM
l e o h j's Avatar
Default Re: DA exhaust on EFs? (artNmotion)
i bringed this post alive. and yes i searched that's why i found this post so that i will not be flammed for creating a new one.
anyway i would like to ask the same question.. will the DA 90-91 exhaust fit on EF or CRX?
thanks
Old Feb 25, 2005 | 09:58 AM
90civichbsi's Avatar
Default Re: DA exhaust on EFs? (leohj)
i cant confirm this but i am pretty sure all you would need to do is shorten the midpipe. if im not mistaken, the rear hangers are in the same place
Old Feb 25, 2005 | 11:40 AM
JUSTCRX's Avatar
yep, u need to shorten the midpipe cuz the wheel base on a DA is longer than a EF.
on the other hand, you need to shorten the midpipe also if you wanna use a EF hatch exhaust on a CRX.
the axle back looks to be the same on the DA and EF but they are not, the curve where it goes thur the rear lca is longer on a DA. hanger locations are the same.
Old Feb 26, 2005 | 01:16 PM
l e o h j's Avatar
thanks for the reply guys! i just wanted to know if it would bolt on. so the mid pipe needs to be shorten huh, ok then..
thanks
and sorry for hi-jacking this thread.
Mike_ef
Dec 16, 2012 07:47 AM
denraweb
Sep 1, 2007 09:08 PM
409-Ef8
Jan 21, 2007 10:11 PM
D3U1LT
Jun 25, 2006 06:00 PM
