89 Accord
Old Feb 13, 2005 | 06:45 PM
Stevorh's Avatar
Default 89 Accord
What motors can you swap into the 89 accords?
Old Feb 13, 2005 | 06:52 PM
propwdialogue's Avatar
Default Re: 89 Accord (Stevorh)
well, for you probably a d or b series swap would be the easiest. if you want a whole lot more detail, check out http://www.3geez.com they are all about the 3rd gen accords and can give you a lot more information that us lowly h-ters can
Old Feb 14, 2005 | 09:30 AM
Vanilla Sky's Avatar
d-series isn't worth it, and placeracing (the only guys that made mounts for this application) went under... the only swap you can do without much hassel is the b20a that is stock in the 85-88 accords in Japan... you can get them in the general export models, but the japanese engines have more power...
Old Feb 14, 2005 | 11:36 AM
TxTuner
Guest
Posts: n/a
Default Re: (Vanilla Sky)
Go ***** to the wall and drop an H22 in that bi0tch!! Nothing says sleeper like an N/A H22 powered 3g
Old Feb 14, 2005 | 12:01 PM
if you want an h22 accord, get at least a 4th gen...
Old Feb 14, 2005 | 01:55 PM
Stevorh's Avatar
So it's a B20a? I don't see that on my engine list. You said it was JDM?
Old Feb 14, 2005 | 05:40 PM
yes... usually you'll find it in the states because an importer imported it by mistake, thinking it was the newer b20... call around and ask for the JDM accord B20... if they don't know that the accord came with one, take your business elsewhere
friscorep
Apr 16, 2007 07:31 AM
elbrendo
Jan 23, 2007 12:22 PM
IcebergMan
Feb 3, 2006 05:39 PM
Egi7
Jul 16, 2005 09:22 AM
