Types of gas/% to use
I just got into a little welding, I have the opportunity to work with tig/mig machines and just wondering what gas to use on metals, the more common, cheaper metals ie: mild steel/aluminum - or any metals for that fact.
so far ive been using argon for both machines.
Also what do you set the pressure to on the gauges for gas?
maybe get a information list going
Argon is great for pretty much everything on a TIG welder, however C10 (10% CO2, 90% argon) is a little better for stainless steel welding, the small amount of CO2 helps bite into the stainless more.
As for MIG, Pure Argon is used for aluminum MIG welding, C25 (25% CO2, 75% Argon) for Mild Steel, and Tri-Mix (dont remember the %s) for stainless steel.
I used 100% argon for everything on my mig, no problems with stainless or mild steel, aluminum welds were horrible, but I'm not all that sure if it was the gas.
rollercosta123
Welding / Fabrication
Jul 15, 2006 11:39 AM
ExploitedRacing-HR
Dec 16, 2004 03:17 AM
