Paint GURU's need your help.
Old Feb 13, 2005 | 06:10 PM
sniperslayer's Avatar
Default Paint GURU's need your help.
K, i recently painted my CF hood, and everything was PERFECT, until i did the last spray and i dripped quite a bit of paint onto the hood [it came out as 1 blob] and was on the hood, scared to wipe it off i tried to blow the paint in an attempt to spread the paint out.
Anyways now there is a large streak of paint which is above the rest, it's very visible, i touched up the 1 spot where the paint had a hole in it and was lower than the rest with a filler primer, but now there still is the streak.
Should i wetsand? or just dry sand it with a low grit, then high and repaint? i'm scared to use a high grit because the whole hood is painted fine already, except for that 1 spot.
Old Feb 13, 2005 | 09:02 PM
Default Re: Paint GURU's need your help. (sniperslayer)
anyone?
Old Feb 13, 2005 | 09:16 PM
EKFerioHawaii's Avatar
ummm....i guessing you painted primer, base, clear.
wetsand to base. Re-base. Clear.
Good Luck
nickmcpher
Paint and Body
Mar 17, 2008 09:38 AM
scorro1
Apr 26, 2006 01:14 PM
Flux
Mar 20, 2003 07:59 PM
GeorgeY
Apr 29, 2002 01:50 PM
