level suspension for 93 accord
Old Feb 13, 2005 | 05:17 PM
LawlessOne's Avatar
Default level suspension for 93 accord
I've seen a lot discussed on suspensions on this forum, but am left with a question none the less.
I was considering Eibach springs, I know they rock and have a good reputation.
But I don't want the "boat look" and the pro kit was addressed as resulting with this "front higher than back look".
So my question is:
What springs can I get that will keep my 93 accord level?
I think I will go with Tokico Blues and am just an average driver.
I don't want to drop it enough to require the addition of camber adjustments. (unless someone has an inexpensive, easy do it yourself solution for the camber kits).
Thanks!
Old Feb 13, 2005 | 06:46 PM
propwdialogue's Avatar
Default Re: level suspension for 93 accord (LawlessOne)
ive heard great things about the h&r sports, and once i get the cash, that is what I will be putting on my accord. of course if you really want to spend some money, you chould go for ground control coilovers and that way get exactly the height you want front and back.
Old Feb 13, 2005 | 06:52 PM
LawlessOne's Avatar
Yea, but the coilovers are a little too much for an average driver and the added expense.
The HR's drop 2" I think, and that will create a need for camber adjustments?
Old Feb 13, 2005 | 06:54 PM
Default Re: (LawlessOne)
actually, 1.7" front and 1.5" rear (to compensate for boat look). so you should not need a camber kit. once you install them, get an alignment. after a couple of weeks of driving and giving them a chance to settle a bit, go back to the alignment shop and get re-aligned. you should be good to go
Old Feb 13, 2005 | 07:00 PM
LawlessOne's Avatar
Sounds good to me : )
preludebro
Mar 3, 2011 03:58 PM
88LSCRX
Classic Hondas
Jun 8, 2008 10:21 AM
89POS
Suspension & Brakes
Nov 8, 2006 02:01 PM
89ShadowAccord
Oct 21, 2005 02:13 PM
iLLegaL
Jan 10, 2005 10:51 AM
