Did swap NO SPARK MIGHT PAY IF SOMEONE CAN COME OVER AND START MY CAR In POMONA
Old Feb 13, 2005 | 03:21 PM
SOHCEK-Turbo's Avatar
Default Did swap NO SPARK MIGHT PAY IF SOMEONE CAN COME OVER AND START MY CAR In POMONA
Did a d15b swap on my ef and now I am not getting any spark I had a d16z6 before it and never had a problem didnt do any wiring changes or anything. There is no current coming out of the 7 wire dizzy plug. Already tried 2 different dizzy's. I checked my grounds and they look ok. so if someone can come down and check it out and get a second opinion I will give cash depending on how much work it was put down. Anyone had this problem before. Dont know maybe I am overlooking something???
Old Feb 13, 2005 | 03:33 PM
Default Re: Did swap NO SPARK MIGHT PAY IF SOMEONE CAN COME OVER AND START MY CAR In POMONA (EKSOHCV-TechRid
up
Old Feb 13, 2005 | 03:38 PM
UltimX's Avatar
What does it do when u turn the ignition?
Old Feb 13, 2005 | 03:49 PM
It cranks over but no spark?????
So its not the starter.
Old Feb 13, 2005 | 03:56 PM
Anyone else?
Old Feb 13, 2005 | 04:04 PM
UltimX's Avatar
Double check the wiring, are you sure ur not getting spark? it could be no fuel. If u just did a engine swap and no wiring, then its user error(assuming the engine can just swap in).
Old Feb 13, 2005 | 04:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UltimX &raquo;</TD></TR><TR><TD CLASS="quote">Double check the wiring, are you sure ur not getting spark? it could be no fuel. If u just did a engine swap and no wiring, then its user error(assuming the engine can just swap in).</TD></TR></TABLE>
No you didnt read correctly I had a d16z6 in there already swapped. Did the mpfi wiring about a year ago. And I know I am getting no spark because I checked the plugs. And checked for current. Thanks anyway. ANYONE ELSE?????
Old Feb 13, 2005 | 04:23 PM
Fuel is ok I could even smell it.
Old Feb 13, 2005 | 04:36 PM
SwissChEz82's Avatar
When you wired it, did you have to splice any wires or did you just pop pins?
Old Feb 13, 2005 | 05:39 PM
ServiceAdvisor's Avatar
Tossing any codes? I was in Riverside today at the pick a part pulling a trans. Maybe I can help you this friday. - Darrell
Old Feb 13, 2005 | 05:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SwissChEz82 &raquo;</TD></TR><TR><TD CLASS="quote">When you wired it, did you have to splice any wires or did you just pop pins?</TD></TR></TABLE>
I spliced wires from the obd1 harness. Like I said I did the wiring about a year ago and havent done any changes. So I really dought that it is the problem.
Old Feb 13, 2005 | 06:03 PM
Default Re: (DOHCZCCRXSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DOHCZCCRXSi &raquo;</TD></TR><TR><TD CLASS="quote">Tossing any codes? I was in Riverside today at the pick a part pulling a trans. Maybe I can help you this friday. - Darrell</TD></TR></TABLE>
No, no codes.
Old Feb 13, 2005 | 06:42 PM
Default Re: (EKSOHCV-TechRider)
anyone else????
Old Feb 13, 2005 | 07:12 PM
thumbtack's Avatar
check the grounds on the thermostat housing... and do you have another distributor you can try?
Old Feb 13, 2005 | 07:17 PM
phan's Avatar
Default Re: (thumbtack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thumbtack &raquo;</TD></TR><TR><TD CLASS="quote">check the grounds on the thermostat housing... and do you have another distributor you can try? </TD></TR></TABLE>
yup, beat me to it. sounds like an unhooked ground issue.
Old Feb 13, 2005 | 07:45 PM
Default Re: (phan)
Yup tried another dizzy and bastered turned on. Thanks everyone. 1 out 3 dizzys work .
Old Feb 13, 2005 | 07:47 PM
thumbtack's Avatar
cool thanks for replying and telling us what fixed it too. Nice to see someone follow a thread through.
typeRef
26
Nov 6, 2012 07:55 PM
AH419
65
Aug 25, 2012 04:14 AM
McLovin
15
Feb 21, 2006 11:15 AM
90crxb16a
Jul 11, 2003 03:00 PM
[626]95-GSR
Feb 14, 2002 03:11 PM
