remorve interior door panel 92 accord
Old Feb 13, 2005 | 02:18 PM
dkmoen's Avatar
Default remove interior door panel 92 accord
Have taken out all the screws and can't seem to get the panel off. Something seems to be holding it near the top of the door. Any ideas?! Rear door panel.
Old Feb 13, 2005 | 02:58 PM
hatchinprogress's Avatar
Default Re: remove interior door panel 92 accord (dkmoen)
did you remove the "plate" that is under the handle? did you remember to pull the handle open(when you try to slide off the panel)
Old Feb 13, 2005 | 07:42 PM
propwdialogue's Avatar
Default Re: remove interior door panel 92 accord (hatchinprogress)
there is a sort of "lip" that goes down into the window, pull up as you pull out, and it should come off
Old Feb 14, 2005 | 07:34 AM
icedplaya123's Avatar
there should only be like 2 or 3 screws holding the door panel on the rest is just clips that are built into the door panel its self, remove the door handle, the 2nd is behind the door handle dont remember if theres one in the lower part, but after u remove all the screws run ur fingers around the lower part and try to lift it until u hear a pop then continue to run your fingers around it until its almost free then just lift the door panel off.
Old Feb 14, 2005 | 11:41 AM
TxTuner
Guest
Posts: n/a
Default Re: remove interior door panel 92 accord (icedplaya123)
MAKE SURE you have ALL of the screws out before you start pulling. After they are out it's just clips and a little tugging will break the panel free
Old Feb 14, 2005 | 11:45 AM
micksf22accord's Avatar
There is a screw in the handle take it out and lift up.
Nuts
Honda S2000
Aug 7, 2008 06:32 PM
todd.ludwig
May 1, 2006 02:27 AM
manishhb
May 19, 2005 06:56 PM
[HrZn]4life
Feb 11, 2003 01:21 PM
onyx00
Sep 5, 2001 12:44 PM
