wiring problems?????
Old Feb 13, 2005 | 01:01 PM
onekoop's Avatar
Default wiring problems?????
ok i have a 91 crx si with a 96 b18b motor. I have been having some wiring issuses with no fuel comming through the injectors. I replaced the injectors and the ecu and it didnt work. Untili was just messing with the ecu, injectors, relay, spark plugs, dizzy and it started and it worked. I got it running and i blew my tranny so i replaced that within 3 days and i drove it the day i got my tranny and it died on me on the road again. Same thing i wasnt gettin any fuel thru the injectors again. I played with all the wires and i pushed all the wires in the pinouts by the ecu and harness plugs. I get fuel to the rail just not through the injectors. I also get power to the injector plug but for some reason im not gettin fuel through.
Old Feb 13, 2005 | 01:07 PM
thumbtack's Avatar
Default Re: wiring problems????? (JDMpnOi)
check your fuel pump wires for grounding out?
rlembitz
Dec 24, 2010 09:04 AM
wburke69
Aug 9, 2010 09:19 AM
mikester1222
17
Apr 18, 2008 07:32 PM
jumpmann23
Aug 5, 2003 05:37 PM
