Hatch opening issues
Old Feb 13, 2005 | 10:34 AM
1999gs-r's Avatar
Default Hatch opening issues
I have a 1999 3dr gs-r. The latch under the lip on the hatch doesn't open the trunk anymore. I have to use my key turning it all the way to the right to open it. I took off the back pnl and operated the latch and I can here it trying to do something and I can see the rod moving only a little not enough to release the door. Is that the actuator assembly (Illustration 25) or the tailgate lock assembly (Illustration 14) Per http://www.acuraautomotivepart...y.jsp? Any help would be great.
Thanks in advance.
Old Feb 13, 2005 | 12:08 PM
NatrulyAspirated's Avatar
Default Re: Hatch opening issues (1999gs-r)
i have the same problem. i thought it was just my car. anyone know the problem?
Old Feb 13, 2005 | 03:03 PM
1999gs-r's Avatar
Anyone?
Old Feb 13, 2005 | 04:24 PM
IggyBcool's Avatar
give her some good o'l wd40 . iv heard of that problem and the most common fix iv heard is just take it to a honda or ac dealership and have them fix it
Old Feb 14, 2005 | 10:27 PM
Default Re: (99LStegra)
tried wd-40 and silicon oil spray before didnt do anything. theres got to be a way to fix it without the dealer. anyone?
Old Feb 15, 2005 | 06:16 AM
1999gs-r's Avatar
I am going to order the ACTUATOR ASSY only because it sounds like the motor is having trouble releasing the lock. I will let you know if it works. The part is only 59.00 dollars so it's not to expensive.
Old Mar 10, 2005 | 08:06 AM
1999gs-r's Avatar
Well I received the ACTUATOR ASSY and installed it today. It works like new. Took 10 min to install. The motor must ware out after a while. I just thought I would share this info to those who are getting tired of using your key to open the trunk.
thundernoodle
Apr 28, 2010 06:35 PM
sinatra
Feb 6, 2009 09:15 AM
redacura
Sep 26, 2005 07:33 PM
98GeeYes-Are
Jun 27, 2003 12:52 PM
camera obscura
Feb 27, 2003 06:14 PM
