Help with ZC Swap in 94 Civic EX!!!!
Old Feb 13, 2005 | 08:27 AM
LSVTEC 91 Civic's Avatar
Banned
Default Help with ZC Swap in 94 Civic EX!!!!
Heres the deal. We're working on a 94 civic EX, there is a DOHC ZC bolted in. Here is the problem... the OBD1 SOHC Distributor that came in the car will not bolt up, and the OBD0 ZC Distributor won't wire up to the EX harness. What kind of distributor will we need to make this work? The car still has the EX wiring harness and it does not currently have an ECU. The things I need to know are, which distributor do we need and which ECU do we need. Any help is appreciated, we're trying to get this car on the road. Thanks HT!
- LSV
Old Feb 13, 2005 | 11:39 AM
Banned
Default Re: Help with ZC Swap in 94 Civic EX!!!! (LSVTEC 91 Civic)
Bump!
Old Feb 13, 2005 | 01:01 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Bump! </TD></TR></TABLE>
Anybody?
Old Feb 14, 2005 | 02:42 PM
Banned
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSVTEC 91 Civic &raquo;</TD></TR><TR><TD CLASS="quote">Anybody? </TD></TR></TABLE>
Old Feb 14, 2005 | 02:45 PM
DJ_SaNdOz's Avatar
I'm not sure on the dizzy, but for the ECU I'd say get an Uberdata chipped P06 w/ an LS program & tune it from there.
Old Feb 15, 2005 | 02:03 AM
Banned
Default Re: Help with ZC Swap in 94 Civic EX!!!! (DJ_SaNdOz)
Thanks, Bump!
Old Feb 15, 2005 | 02:10 AM
gumbii's Avatar
i don't understand... ¿why won't it bolt up... we did this swap and we had to use a bolt with a washer to hold it from the bottom, and a C-clamp on the top... it was a obd-0... and we used the stock obd-0 distributor... then we had to get the top bracket from an 92 LS block from the junkyard, and it made it bolt up to at least the top bolt... that was good enough...
i don't know how you are going to do it to convert obd0 to obd1... good luck....
tevezjdm3012
Jul 10, 2011 04:59 AM
tkda
Feb 13, 2009 10:30 AM
v6s12
May 14, 2008 12:13 PM
blah13
Apr 28, 2003 06:23 PM
