poor gas mileage
Old Feb 12, 2005 | 11:53 PM
Komptech's Avatar
Default poor gas mileage
driving a 01 gsr, getting bad gas mileage? i can get about 260miles tops(with alot of freeway) on a full tank. Never can pull 300miles out of a full tank. All sock cept header. exhaust, intake. help
Old Feb 13, 2005 | 06:42 AM
CNSK's Avatar
Default Re: poor gas mileage (Komptech)
bad o2?
Old Feb 13, 2005 | 08:34 AM
NeoGSR's Avatar
Default Re: poor gas mileage (CNSK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CNSK &raquo;</TD></TR><TR><TD CLASS="quote">bad o2?</TD></TR></TABLE>
that's what i was thinkin'
Old Feb 13, 2005 | 09:55 AM
azzenco's Avatar
Default Re: poor gas mileage (NeoGSR)
How's your tire pressure?
Old Feb 13, 2005 | 08:53 PM
Komptech's Avatar
Default Re: poor gas mileage (azzenco)
its normal... im running 40 series?
Old Feb 13, 2005 | 09:02 PM
Monkey Z.'s Avatar
try running sea foam (1/2 through brake booster line into intake manifold and 1/2 poured into gas tank)
Old Feb 13, 2005 | 09:09 PM
cnydc2's Avatar
Default Re: (DarkblueInteg)
Is there a check engine light on?
Old Feb 13, 2005 | 09:43 PM
gsr_to_the_MAX's Avatar
Default Re: (cnydc2)
i only get 260 tops as well. but i thats cuz i took off my o2 sensor for my header.
Old Feb 13, 2005 | 09:44 PM
Damnit's Avatar
umm jw but do u drive normally like low revs? or u always do high revs? cuz the revs really affect my gas milage for my car
Old Feb 13, 2005 | 09:51 PM
Komptech's Avatar
Default Re: (Damnit)
generally i shift at about 3k everytime.. rarely i hit vtec all the time. but i was talkin to a friend , and i think maybe cuz i downshift? i downshift everyday i drive... all bad
Old Feb 13, 2005 | 09:52 PM
Komptech's Avatar
Default Re: (gsr_to_the_MAX)
what kind of header you running gsr_to_the_MAX?
Old Feb 13, 2005 | 10:07 PM
Default Re: (Komptech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Komptech &raquo;</TD></TR><TR><TD CLASS="quote">what kind of header you running gsr_to_the_MAX?</TD></TR></TABLE>
jdm itr 4-1
Old Feb 14, 2005 | 10:34 PM
Damnit's Avatar
well have u tried driving on a whole tank withouth the downshifting? cuz if u downshift and let go of ur clutch = high revs which total = poor gas mileage. cuz i did it on a bmw and they have the guage that tells u how much gas u using, and its always at the lowest end when i downshift soooooooooooooooo ya
Old Feb 14, 2005 | 11:08 PM
Slain's Avatar
whens the last time you did a tune up ie ( maintence parts plugs wires , dist cap and rotor, valves adjusted etc)
Old Feb 16, 2005 | 04:44 PM
Komptech's Avatar
Default Re: (Slain)
well i just changed my oil about 100 miles ago. As far as complete tuneups, havent had once since we bought the car. We bought the car with 8k miles, now it has 17k miles. I have eliminated my downshifting completely, unless goin down hill. Maybe its time for a tune up or check up?
Old Feb 16, 2005 | 05:03 PM
xscape's Avatar
How much is average on a full tank?
ive been getting about 400km (240 miles) off 40 litres (full tank) when driving normally, and its been this way since i got the car in august.
Old Feb 16, 2005 | 05:10 PM
confucius's Avatar
thats pretty bad for a 4 cylinder.
my old toyota camry v6 family car got about the same mileage.
Old Feb 16, 2005 | 05:11 PM
The-LS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Damnit &raquo;</TD></TR><TR><TD CLASS="quote">well have u tried driving on a whole tank withouth the downshifting? cuz if u downshift and let go of ur clutch = high revs which total = poor gas mileage. </TD></TR></TABLE>
I believe your injectors shut off when you downshift to high revs (overun vacuum), the car knows you've downshifted and wouldn't want to waste gas either.
Old Feb 16, 2005 | 05:18 PM
Endless STi's Avatar
Default Re: (Black-LS)
i get around 220-250 tops.
both city and highway driving daily.
Old Feb 16, 2005 | 05:50 PM
xscape's Avatar
Yes id have to say that im dissapointed with the mileage of b-series engines.
My old 2.2 litre mx6 turbo, fited with a t28 on 12psi got similar, if not better mileage
Old Feb 16, 2005 | 06:14 PM
CougDG's Avatar
Default Re: (xscape)
take out your spark plugs and look at them. It could also be you're driving habits... Stop and go much?
Old Feb 16, 2005 | 06:26 PM
tnord's Avatar
Default Re: (CougDG)
when i bought my GSR, i used to have to stretch to get 25mpg out of a tank. after changing fuel filter, running some redline fuel system cleaner, adjusting the valves, correcting the cam timing, and correcting the ignition timing, i'm up to 27.5 mpg on the last tank. i checked today for the first time since november and my tires were down to about 23psi (i really don't care about wear since they're junk tires). now i've got them all up around 40, so we'll see how much of a difference it makes. i haven't even changed cap, rotor, plugs, or wires yet.
get the car running right and your fuel economy should be
Old Feb 17, 2005 | 07:59 AM
JDMLEROY's Avatar
WHAT KIND OF GAS U RUNNING???? USE A HIGHER OCTANE IT MIGHT WORK...
Old Feb 17, 2005 | 08:09 AM
greaseball's Avatar
Default Re: poor gas mileage (JDMLEROY)
i'm getting about 180-200 miles per tank. my '50 chevy gets better gas mileage! lol
Old Feb 17, 2005 | 08:21 AM
Default Re: poor gas mileage (greaseball)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by greaseball &raquo;</TD></TR><TR><TD CLASS="quote">i'm getting about 180-200 miles per tank. my '50 chevy gets better gas mileage! lol</TD></TR></TABLE>
it could be cuz you have 199whp built motor?
