91 integ LS ecu
Old Feb 12, 2005 | 10:46 PM
DaMmniTz's Avatar
Default 91 integ LS/RS ecu
I'm currently using a pm6 si ecu for my zc swap and i was told by a fellow of honda tech that it's better to use the 91 integ ls/rs ecu which has a 7k redline and that you can get more aggressive fuel map and higher rpms. So if this is correct, I was wondering what's the ecu code of a 91 LS/RS ECU? Thanks.
Old Feb 12, 2005 | 10:53 PM
crxnj's Avatar
Default Re: 91 integ LS/RS ecu (DaMmniTz)
pre-obd pr4
The 88-89 integra ecu is better though..Or better yet the zc ecu
Old Feb 12, 2005 | 10:55 PM
hatchinprogress's Avatar
Default Re: 91 integ LS/RS ecu (Mr.speaker)
i have a 91 pr4 feels good but you will run alot richer
Old Feb 12, 2005 | 10:56 PM
Default Re: 91 integ LS/RS ecu (hatchinprogress)
in fact i got one for sale if you need one pm me
Old Feb 13, 2005 | 08:19 AM
ssl2k's Avatar
for the dohc zc you'll want the pg7 ecu off of the 88-89 tegs
Old Feb 13, 2005 | 09:29 AM
Default Re: (ssl2k)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ssl2k &raquo;</TD></TR><TR><TD CLASS="quote">for the dohc zc you'll want the pg7 ecu off of the 88-89 tegs</TD></TR></TABLE> but you can use a pr4....but a pg7 would work better with the zc
FastHatch90
12
Jun 17, 2006 11:31 PM
crx5
May 4, 2005 07:31 AM
4door93civic
Jun 4, 2004 09:42 PM
mateencrx91
Nov 20, 2003 11:32 AM
bullock
Oct 22, 2003 05:48 AM
