Finally put bolted up my transmission to my engine and...
Old Feb 12, 2005 | 09:44 PM
85mm LS VTEC's Avatar
Default Finally bolted up my transmission to my engine and...
I noticed that the flywheel is exposed on the bottom part of the transmission next to the oil pan. Is it suppose to be like that or am I missing a part of the lower transmission? It a YS1 bolted up to a LS/VTEC, thanks.
Old Feb 12, 2005 | 09:51 PM
2G0S0R1's Avatar
New User
Default Re: Finally bolted up my transmission to my engine and... (85mm LS VTEC)
Mine has a small square opening to the flywheel, Im almost positive it is supposed to be like that for possible heat or drainage purposes or something.
Old Feb 12, 2005 | 10:00 PM
88crxsir's Avatar
Default Re: Finally bolted up my transmission to my engine and... (2G0S0R1)
that is correct..........there is no plate to cover it, it's for heat discipation!!
Modified by 88crxsir at 3:08 PM 2/16/2005
Old Feb 12, 2005 | 10:40 PM
LSvtec03's Avatar
Default Re: Finally bolted up my transmission to my engine and... (88crxsir)
um, yes, there actually is a plate that is supposed to go there. it's not open for any purpose. however, it's ok if you're plate isn't there. i dont have it on mine, and i know several of my friends have left theirs off after a swap.
Old Feb 12, 2005 | 11:36 PM
KRaZee_TiNy's Avatar
yes and it doesn't affect you tranny, but it get dirty in there.
grenade foot soldier
Aug 31, 2005 11:45 PM
RACEPAK
18
Jul 11, 2005 06:21 PM
Hatch It
Jun 7, 2005 02:08 PM
lildrgn2.0
Jun 22, 2004 06:56 AM
Hcivic88
12
Aug 29, 2002 05:50 PM
