lookin to do my brakes
Old Feb 12, 2005 | 09:21 PM
zyntax's Avatar
Default lookin to do my brakes
i was lookin get something better than OEM for a change and i like the PowerStop Pro Stop brakes which are dimpled and slotted. Does the dimpling really have any effect on the braking, or is it just a cosmetic type thing?
lemme know what you guys think about these rotors also and reccomend any others you guys are running and like.
also was checkin out the AEM pads, they seem like a decent buy.
lemme know what you guys think.
Old Feb 12, 2005 | 09:25 PM
garlic jr's Avatar
Default Re: lookin to do my brakes (zyntax)
id use autozone rotors and their best pads. both carry a 2 year warranty and such... eat them up like crazy as much as u want. return for new
Old Feb 12, 2005 | 09:29 PM
crxgator's Avatar
Default Re: lookin to do my brakes (garlic jr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garlic jr &raquo;</TD></TR><TR><TD CLASS="quote">id use autozone rotors and their best pads. both carry a 2 year warranty and such... eat them up like crazy as much as u want. return for new </TD></TR></TABLE>
AZ has 3 month warrenty on rotors and either 2 year or lifetime on pads depending on which you get...
id get AZ rotors and Hawk HPS pads, thats my combo and i love it...
Old Feb 12, 2005 | 09:31 PM
garlic jr's Avatar
Default Re: lookin to do my brakes (crxgator)
Valucraft Rotors have a 3 month. Duralast's have a 2 year. i work at autozone. i should know
Old Feb 12, 2005 | 09:32 PM
HatchBox's Avatar
Skoobie no more...
gator did too...
Old Feb 12, 2005 | 09:33 PM
crxgator's Avatar
Default Re: lookin to do my brakes (HatchBox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchBox &raquo;</TD></TR><TR><TD CLASS="quote">gator did too... </TD></TR></TABLE>
****, i just check their site, its 2 years now...
sweet...although my warrenty is up on these rotors...
Old Feb 12, 2005 | 09:51 PM
zyntax's Avatar
thanks for sidetrackin' guys, i wanted to know about the powerslot rotors aswell...heh
i don't have an autozone around here, anything decent at a pep boys? probably the same stuff with different names.
as i said, i don't want the oem spec stuff, i want something that's going to perform a little better as i'm going to be going to the track.
Old Feb 12, 2005 | 10:08 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyntax &raquo;</TD></TR><TR><TD CLASS="quote">thanks for sidetrackin' guys, i wanted to know about the powerslot rotors aswell...heh
as i said, i don't want the oem spec stuff, i want something that's going to perform a little better as i'm going to be going to the track.</TD></TR></TABLE>
how did we side track?
we are giving a better suggestion so you dont waste your money on stuff you dont need...check out the RR forum, most use AZ rotors because they are a wear item...no need to spend 60 bucks a rotor when you can pay 20 a rotor that does the same thing...
Old Feb 12, 2005 | 10:16 PM
eda6's Avatar
When you get new rotors, is it necessary to have new rotors turned?
Old Feb 12, 2005 | 10:20 PM
CRseXy's Avatar
AGREE!!! I wouldnt worrie so much about Rotors right now. There virtualy all the same. unless your going to upgrade to bigger rotors, and bigger calipers. You arnt doing squat with "aftermarket" Rotors. You have failed to understand that TIRES have a BIG say in ur stoping distance. my DX will lock the tires EASY, because my tires are in need of change. Get some sticky Icky tires, THEN think about uping the brake system.
hey, if you wana do a some small things. If you dont have 4 wheel disk, go get some off an SI, along with a Proportioning valve, and have a field day.
That would do more to stop then sloted\dimpled\cross drilled rotors.
Old Feb 12, 2005 | 10:25 PM
zyntax's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">
we are giving a better suggestion so you dont waste your money on stuff you dont need...check out the RR forum, most use AZ rotors because they are a wear item...no need to spend 60 bucks a rotor when you can pay 20 a rotor that does the same thing... </TD></TR></TABLE>
ok then, you just told me the autozone rotors will perform the same as the slotted rotor? if that IS the case, then i do appreciate the suggestion and i may go that route, i just want to get somthing that will have awesome stopping power, and i figured i may aswell get something different then the "autozone" type rotors i've been using for years.
Old Feb 12, 2005 | 11:15 PM
thumbtack's Avatar
Default Re: lookin to do my brakes (eda6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 &raquo;</TD></TR><TR><TD CLASS="quote">When you get new rotors, is it necessary to have new rotors turned?</TD></TR></TABLE>
No! They are brand new... you "turn" old rotors if they are still in spec and in great shape. With new ones, when you take them outta the box, spray them with brake cleaner to get the oil from the packing off of them. That's it.
Old Feb 13, 2005 | 04:33 AM
garlic jr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zyntax &raquo;</TD></TR><TR><TD CLASS="quote">ok then, you just told me the autozone rotors will perform the same as the slotted rotor? if that IS the case, then i do appreciate the suggestion and i may go that route, i just want to get somthing that will have awesome stopping power, and i figured i may aswell get something different then the "autozone" type rotors i've been using for years.</TD></TR></TABLE>
if u slam on the brakes to stop. with your mods it will be the same as if u had power slotted. u will find it suprising how much power u actually need before needing to have cross drilled or slotted rotors to stop. but if you street race on not so long streets then maybe this is why u are so concerned...find a longer street or better yet keep it on the track
Old Feb 13, 2005 | 04:46 AM
zyntax's Avatar
find a longer street or better yet keep it on the track </TD></TR></TABLE>
like i said, it's going to be for the track.
thanks for the suggestions maybe i'll take a look at the rotors from autozone or pep boys and get some decent pads.
i still think upgraded rotors would help on the track..
Old Feb 13, 2005 | 05:19 AM
T-Mo's Avatar
I tend to disagree with the slotted, cross drilled. or whatever (after market rotors).
I had slotted ones one my Prelude and when stopping the whole cars shakes. So, I tried crossdrilled and got the same thing. Now I am using just some regular rotors and it made a world of difference. No shaking, vibrating, etc and I got the 2yr warrenty.
Old Feb 13, 2005 | 07:51 AM
JDMThoughts's Avatar
From: Standing on the corner selling cocaine, rippin shows live on stage for hoes yellin my name
Default Re: (T-Mo)
I have Brembo slotted on my GSR, they are kinda cool I guess, but they really don't benifit me for what my car is used for. The biggest investment you can make is getting good brake pads, that will make just as much of a difference as good tires. I would reccomend some Cobalt Friction, I spent extra and bought Endless pads, but I probably could've gotten the same performance as Cobalt or Carbotechs.
Old Feb 13, 2005 | 08:08 AM
crexer's Avatar
Default Re: (JDMThoughts)
its covered at least 4 times a day on here. Most people will tell you to just get blank rotors. Cross drilled are known to develop pressure cracks and slotted is just unneccesary. I can promise you there will be no difference in braking whether your rotors are slotted or not. I also dont suggest on the AEM pads because I had a set for a year and one side cracked both pads when I went to change out my brakes for the DA integra setup. Get you some blank rotors and a set of Hawk pads, maybe even a 90-91 ex MC and be done.
sin2o3
Sep 5, 2007 12:20 PM
mportracer33
Honda S2000
Apr 2, 2007 09:18 AM
Lauj87
Feb 18, 2007 07:47 PM
matto2413
Feb 1, 2005 03:31 AM
BlackOut21
Jan 7, 2003 10:37 AM
