can i use crx shift linkage with a b16
i was told i could use the crx shift linkage with the b16 as long as i shortened it is this true and how much would i shorten it.
actually you would have to lengthen it...
best thing to do is buy custom linkage you can pick one up for $100 and its well both it
you could get an 91 teg linkage and i think you have too shorten it 3inches i wouldnt play around with that lots of companys making linkages for cheap look up ebay i did
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tc_gts »</TD></TR><TR><TD CLASS="quote">actually you would have to lengthen it...
you could get an 91 teg linkage and i think you have too shorten it 3inches i wouldnt play around with that lots of companys making linkages for cheap look up ebay i did</TD></TR></TABLE>
thats right....
thats right....
From: I told you to wait in the truck in Texas, United States
My first swap,I took over a year to get all the right parts
and to convince myself to tear apart my daily-driver.
The second swap I did for a friend was in and running after 8 hours..
If you check the FAQ section: https://honda-tech.com/zerothread?id=637661
you will be doing us all a big favor...
94lvstreetscene
Nov 10, 2006 08:06 PM
