Actuall VSS sensor wire colours?!?!?
Old Feb 12, 2005 | 07:55 PM
HamiltonRex's Avatar
Default Actuall VSS sensor wire colours?!?!?
My speedo dosent work, did a cluster swap, went from cable to electronic vss. Used a 92-95 civic vss.
I have 3 wires.
Yellow/Blue
Black
Yellow/White
I know black is ground.. and the other 2 are 12V and signal. The question is, which is which. I have searched and found different answers, like the yellow/blue is signal, and others say its 12v
WHICH IS IT?
Thankyou need a speedo
Old Feb 12, 2005 | 11:27 PM
Relic1's Avatar
Yel/Blu - 12v in Run or Start
Blk - ground at thermostat housing
Yel/Wht - speed signal to gauges, cruise and ECU.
Old Feb 13, 2005 | 06:29 PM
Default Re: (Relic1)
Thankyou.
I fixed it and it works! Turns out i had the 12V and signal wires switched.
tractiondeprived
Jun 6, 2006 02:00 PM
b18bEG
Jun 26, 2005 12:36 PM
^Sammy]!.
Feb 12, 2005 09:53 PM
AdamITR
Apr 16, 2003 02:18 PM
