A/F gauge install help
Old Feb 12, 2005 | 05:05 PM
Ricochet.'s Avatar
Default A/F gauge install help
Got a buddy installing one on a '03 Civic. There are four wires coming off his O2 sensor, 2 white, 1 black, and 1 gray. I can't find instructions anywhere.
Old Feb 12, 2005 | 05:23 PM
civictildeath's Avatar
Default Re: A/F gauge install help (Ricochet.)
what color wires are on the gauge??
Old Feb 12, 2005 | 05:25 PM
Frozen E's Avatar
H-T White Ops
just a heads up, unless he has a wideband O2 sensor it's not going to do **** for him. Just a fancy light show.
Old Feb 12, 2005 | 05:29 PM
Ricochet.'s Avatar
^Yes we both know that.
Old Feb 12, 2005 | 05:40 PM
Ricochet.'s Avatar
The wires off the gauge are black, red, and purple. Black and red are for power, purple for the signal, but we don't know which wire to hook it up to on the O2 sensor.
Old Feb 12, 2005 | 05:43 PM
SOHCD16y8's Avatar
im pretty sure it is the gray one, even though its not as good as a wideband it still gives a general idea
Old Feb 12, 2005 | 05:44 PM
SOHCD16y8's Avatar
o yeah make sure you use a tap in connetor, dont just splice it in
Old Feb 12, 2005 | 05:49 PM
Ricochet.'s Avatar
Tap in connector.. is that the kind with two "tubes" and a metal thing in the middle, where you pinch the connector and the metal cuts through the silicone?
Old Feb 12, 2005 | 05:50 PM
Default Re: (Ricochet.)
gauge
red=power
black=ground
purple=to o2 sensor
o2 sensor
2 white=signal
1 black=ground
1 gray=power
might want to have a 2nd opinion on the o2 sensor part
Old Feb 12, 2005 | 05:54 PM
ecahatch's Avatar
Senor Miembro
Default Re: (civictildeath)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">gauge
red=power
black=ground
purple=to o2 sensor
o2 sensor
2 white=signal
1 black=ground
1 gray=power
might want to have a 2nd opinion on the o2 sensor part</TD></TR></TABLE>
purple goes to the white wire in ur ECU plug...the white wire is a lil thicker than the rest
Old Feb 12, 2005 | 05:58 PM
Ricochet.'s Avatar
Default Re: (ECAhatch)
He already tried one of the white wires off the sensor but I'm not sure which one, I'll tell him to try the thicker one if he hasn't already.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ECAhatch &raquo;</TD></TR><TR><TD CLASS="quote">purple goes to the white wire in ur ECU plug...the white wire is a lil thicker than the rest </TD></TR></TABLE>
No. I used to have mine hooked up to the ECU wire and the signal looked like ****. I reconnected it near the sensor, and it's a nice crisp 1 bar instead of 3-4 bars bouncing all over the place.
Old Feb 12, 2005 | 06:03 PM
SOHCD16y8's Avatar
yes thats a tap in connector, in my ek its the white wire but they should all be in the same spot since most o2 are the same, its should be like this
no yes
no no
tap into yes its either the black or grey one
Old Feb 12, 2005 | 06:04 PM
Ricochet.'s Avatar
aaaaaaaaarggghh what wire is it guys!?!?!?
Old Feb 12, 2005 | 06:09 PM
SOHCD16y8's Avatar
whatever the top right wire is when looking straight at the connector
Old Feb 12, 2005 | 06:11 PM
Default Re: (SOHCD16y8)
now which connector the one that goes to the sensor or the on that goes to the car??
Old Feb 12, 2005 | 06:19 PM
SOHCD16y8's Avatar
heres the best drwing i can make
O2 Sensor ------connector,connector---------ECU
l
l
when looking at this connector
random color tap here
same color same color
thats all i got
Old Feb 12, 2005 | 06:21 PM
SOHCD16y8's Avatar
damn it doesn look right the l
l
l
should be pointing to the second connector
Pellegrini808
May 31, 2014 12:03 PM
Qwik_XR
Jul 3, 2006 06:06 AM
PearlWhiteAccord
Dec 31, 2005 01:40 PM
djnikko
Sep 6, 2003 12:25 PM
JaiDM
Jun 18, 2003 10:04 AM
