swaping suspension
Old Feb 12, 2005 | 03:23 PM
xintegr's Avatar
Default swaping suspension
im planing to swap my homboys omni power full coilover for my kyb agx adjustable w/ GC.! on the agx to adjust the firmness u just turn the little thing in the middle to "1" "2" "3" "4" and 1 being the stiffness. how do u adjust it for the omni?
Old Feb 12, 2005 | 03:45 PM
xintegr's Avatar
Default Re: swaping suspension (xintegr)
oh yea his car is a 98 ek and my car is a 98 gsr. would it fit?>
Old Feb 12, 2005 | 05:00 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
the rear will not fit on the lower control arms.
And I do not believe the OmniPower coilovers have adjustable damping.
Old Feb 12, 2005 | 05:30 PM
purplegsr's Avatar
Default Re: swaping suspension (PatrickGSR94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">the rear will not fit on the lower control arms.
And I do not believe the OmniPower coilovers have adjustable damping.</TD></TR></TABLE>
Patrick is right, the Omnis aren't adjustable.
However, I think the EK shocks can be made to go on the DC/EG LCAs, but it would require you to shave a little bit of the LCA bushing off. I think the fork at the bottom of the EK shock is too narrow to fit over the LCA without a bit of shaving. You could try to test fit it and see how much you need to remove, the good news is that the fronts will bolt up perfectly.
Your friends car would probably require some washers or something to make the LCA a bit wider to fit better with your wider forks on the GSR, I don't know if I would trust washers like that over a bushing. Maybe you can swap LCAs as well, that might work.
Old Feb 12, 2005 | 05:35 PM
xintegr's Avatar
hm replacing the lca.. sounds like a good plan
Old Feb 13, 2005 | 09:54 PM
purplegsr's Avatar
Default Re: (xintegr)
I was just thinking about it, and the LCAs should work if you swap them, but you may run into sway bar difficulties on the Integra. I am not sure if all EK LCA had holes for the sway bar, and if it's in a different position than the Integra ones. I would take a look under both cars first and make some measurements.
Orientalbigboi
Sep 8, 2007 11:22 AM
dELfONiK
Jul 30, 2006 02:26 PM
myronwong
12
Feb 5, 2006 03:47 PM
rogue420
Suspension & Brakes
Aug 25, 2005 10:36 AM
fishnfst
Sep 7, 2003 06:58 PM
