Bypass of coolant to Throttle Body
Old Jan 17, 2002 | 05:56 AM
IntegraGSR2000's Avatar
Default Bypass of coolant to Throttle Body
I'm installing a Skunk2 IM and had a couple of ideas I wanted to run by everyone...
I was wondering if I could bypass the coolant fittings that run to my throttle body. I believe they are for the fast idle. I was thinking about simply getting a longer hose and running it from the fitting on the head all the way back to the IAC valve on the back of the Intake Manifold. Wold this work / cause any complications / keep my intake charge any cooler?
I was also wondering if I could route the EVAP hose to the little vacume fitting on the back of the Skunk2 IM if I used a vacume line reducer. Otherwise the instructions say to use a T fitting on the PCV hose to supply vacume to the EVAP.
Thanks for the help guys.
[Modified by IntegraGSR2000, 2:57 PM 1/17/2002]
Old Jan 17, 2002 | 06:32 AM
Doctor CorteZ's Avatar
Default Re: Bypass of coolant to Throttle Body (IntegraGSR2000)
the fast idle thermo switch needs coolant to function properly , the iac just needs it to keep from freezing up - so goin around the fast idle switch wouldnt be a good idea-
-TJ's Avatar
-TJ
You can bypass the bottom of the throttle body and run the coolant line straight to it's next destination. The reason coolant goes through the bottom of the TB is to keep it from icing up in cold climates.
I see you live in MN, so I would NOT recommend bypassing the TB. There are negligable gains doing that anyway.
Old Jan 17, 2002 | 10:48 AM
rainforest's Avatar
Default Re: Bypass of coolant to Throttle Body (-TJ)
all it does is when its cold it will idel funny till the motor wharms up then it should run fine. my friend did the same thing you wnat to do and iam in my crx.
Old Jan 17, 2002 | 10:56 AM
976's Avatar
976
New User
Default Re: Bypass of coolant to Throttle Body (rainforest)
http://lyonel.8m.com/tb_bypass.htm
Old Jan 17, 2002 | 12:11 PM
93LSivic's Avatar
This might help you learn something about what you are going to do. I would not recommend doing this.
https://honda-tech.com/zerothread?id=114032
Old Jan 18, 2002 | 04:38 AM
Mista Bone's Avatar
D Tranny Guru
no gains on dyno from bypassing the coolant lines.
Keep them there!
Old Jan 18, 2002 | 06:14 AM
Default Re: Bypass of coolant to Throttle Body (Mista Bone)
Thanks for the replies guys. I guess I'll hold off on doing this if there are no gains from it. Anyone have any idea on my EVAP question.
imationdawg
Apr 19, 2011 08:14 AM
IntegraGSR1999
Jan 11, 2010 05:54 PM
si_motor_spt
16
Oct 14, 2007 04:57 PM
dem0nk1d
14
Mar 22, 2006 05:57 PM
philly-O
May 25, 2004 04:56 AM
