Full hatch/rear window replacement for DC2??
Old Feb 12, 2005 | 01:38 PM
jBj's Avatar
jBj
Default Full hatch/rear window replacement for DC2??
hey does anybody know how to remove/replace a full hatch with window on a gen3 teg?? i unhooked the hydraulics etc but when i went to lift thehatch up to unbolt it my window broke .
I now have a new one to replace it with but dont want anyother **** to happen... Any ideas anybody??
thanks
Old Feb 12, 2005 | 04:26 PM
jBj's Avatar
jBj
Default Re: Full hatch/rear window replacement for DC2?? (jBj)
any tips??
Old Feb 13, 2005 | 10:28 AM
jBj's Avatar
jBj
buump, nobody has ever removed the rear window/hatch off their integra?
Old Feb 13, 2005 | 12:42 PM
{Mineral Grey} ITR's Avatar
Your best bet is to go with a mobile window installer...they have all the tools and are experienced. I had all my windows taken out.....painted the car...and the same installer reinstalled the windows! It should cost less than $50 for the whole process.
Old Feb 13, 2005 | 01:19 PM
5 Speed AP2's Avatar
You need to unbolt the two (2) hinges hidden inside of the ceiling cover. To get to these hinges you have to first remove a horizontal rubber piece along the edge of the ceiling close to the hatch. Once that is out, jus pulled down on the ceiling cover and the hinges will be all yours to play with.
Old Feb 13, 2005 | 01:26 PM
Default Re: Full hatch/rear window replacement for DC2?? (5 Speed Dc2)
Oh yeah, dont forget to remove the plastic piece on the inside of the hatch that covers the rear windshield wiper motor, you will need to take that off in order to dissconnect the rear defrost wiring etc etc. And if you have a 98+ integ there will be additional wires for the rear hatch lever. Make sure you disconnect all these wires first, or else you will find yourself having to disconnect them while having someone else hold that heavy *** hatch. After they have been removed, pulled them out from the top upper right corner of the hatch and make sure the hatch has no wires tied to it, this way, after you disconnect the rear hydraulics and the hinges it will be an easy removal. Let me know if you need some pics.
Old Feb 13, 2005 | 02:09 PM
jBj's Avatar
jBj
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5 Speed Dc2 &raquo;</TD></TR><TR><TD CLASS="quote">You need to unbolt the two (2) hinges hidden inside of the ceiling cover. To get to these hinges you have to first remove a horizontal rubber piece along the edge of the ceiling close to the hatch. Once that is out, jus pulled down on the ceiling cover and the hinges will be all yours to play with.</TD></TR></TABLE>
so remove the rubber piece thats attached to the glass? and access those hinges from the top of the glass? do i need to remove anything from inside the car to get to them? thanks
Old Feb 13, 2005 | 05:41 PM
Sorry for such a late response, but i jus emailed you some pics. Let me know if you need more info.
Old Feb 23, 2005 | 10:55 AM
jBj's Avatar
jBj
Thanks for the pics user '5 speed Dc2'
Here is how you remove the hatch, thought i would post the pics for future knowledge.
shocker911
Paint and Body
Jun 20, 2011 02:07 PM
8dxhatchy8
19
Feb 15, 2009 02:00 PM
RR98ITR
Jun 21, 2006 09:49 PM
uNF$@#!
Apr 6, 2003 07:24 AM
