Omnipower rear shim kit install
Old Feb 12, 2005 | 12:56 PM
Pompiuses's Avatar
Default Omnipower rear shim kit install
How do I install the Omnipower rear shim kit?
I was just looking at my rear suspension the other day and couldn't figure it out.
Search came up with nothing.
Old Feb 12, 2005 | 01:00 PM
(__________)'s Avatar
Default Re: Omnipower rear shim kit install (Pompiuses)
Look at your rear upper control arm, there are 2 bolts that go into the body, those are the bolts that you take out and replace with the bolts they give you, you put the washers in between the control arm and the body. Same goes for the other side
Old Feb 12, 2005 | 01:04 PM
.water's Avatar
Default Re: Omnipower rear shim kit install (steves98itr247)
how u know when wheel is st8? just eye check?
Old Feb 12, 2005 | 03:19 PM
.RJ's Avatar
.RJ
Default Re: Omnipower rear shim kit install (Chris DC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris DC2 &raquo;</TD></TR><TR><TD CLASS="quote">how u know when wheel is st8? just eye check? </TD></TR></TABLE>
Camber gauge.
Remove Upper Control arm from the trailing arm when you are removing/reinstalling those bolts - you are much less likely to crossthread them this way.
Old Feb 13, 2005 | 03:27 AM
Pompiuses's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steves98itr247 &raquo;</TD></TR><TR><TD CLASS="quote">Look at your rear upper control arm, there are 2 bolts that go into the body, those are the bolts that you take out and replace with the bolts they give you, you put the washers in between the control arm and the body. Same goes for the other side</TD></TR></TABLE>
Won't that push the upper control arm outwards creating positive camber? That's kinda the opposite of what I want
Old Feb 13, 2005 | 05:14 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">That's kinda the opposite of what I want </TD></TR></TABLE>
Thats the only thing shimming the rear UCA is good for.
Old Feb 13, 2005 | 06:05 AM
Pondus's Avatar
Well then you need adjustable upper control arms instead of the shim kit, like these :
This is a set of Ingalls adjustable arms btw.
Old Feb 21, 2005 | 06:31 AM
Pompiuses's Avatar
Default Re: Omnipower rear shim kit install (Pondus)
The Omni rear shim kit also comes with extra bolts. Why use these instead of the stock bolts?
Old Feb 21, 2005 | 06:52 AM
ebelp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pompiuses &raquo;</TD></TR><TR><TD CLASS="quote">The Omni rear shim kit also comes with extra bolts. Why use these instead of the stock bolts?</TD></TR></TABLE>
It doesn't matter which ones you use.
Old Feb 21, 2005 | 07:27 AM
JOHN WAYNE's Avatar
because they are longer than stock (youre adding washers so you need more length)
i dont know why the hell anyone would pay $15 for 4 bolts and 12 washers though. sack up an get your *** to home depot.
Old Feb 21, 2005 | 11:24 AM
stickercuttingcom's Avatar
Put it on, drive it to the alignment shop, show them where to adjust it and you're set.
Aligning a car by eye = more or less impossible.
Old Feb 28, 2005 | 06:38 PM
xoutlawz00x's Avatar
Default Re: (stickercuttingcom)
what is a shim kit whats the point of it??
Old Feb 28, 2005 | 06:49 PM
JOHN WAYNE's Avatar
Default Re: (xoutlawz00x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xoutlawz00x &raquo;</TD></TR><TR><TD CLASS="quote">what is a shim kit whats the point of it??</TD></TR></TABLE>
cheap, DIY rear camber adjustment
brewerkz
Honda CR-V & Element
Jul 23, 2017 07:52 AM
stripes777
Aug 11, 2008 07:50 PM
ef8powr91
Nov 22, 2005 04:50 AM
wdskuk
11
Jul 6, 2004 11:08 AM
