things i should have added when i did my rebuild????
Old Jan 16, 2002 | 11:34 PM
Lei Siew Long's Avatar
Default things i should have added when i did my rebuild????
should i have added a block girdle and upgraded to a vtec oil pump? anything else besides basic bottom end and top end upgrades? because i am planning on running that thing to about 9000 rpm
[Modified by boostedeg6, 8:34 AM 1/17/2002]
Old Jan 16, 2002 | 11:44 PM
VaporTrail's Avatar
New User
Default Re: things i should have added when i did my rebuild???? (boostedeg6)
Moroso oil pan, oil pressure gauge while you're there
Old Jan 17, 2002 | 12:12 AM
Default Re: things i should have added when i did my rebuild???? (VaporTrail)
i'm not sure if the moroso oil pan would be beneficial but, i do have an oil pressure gauge.
Old Jan 17, 2002 | 09:21 AM
paulzy's Avatar
forget the vtec oil pump, you should have gotten the z10 or prodrive units
Old Jan 17, 2002 | 09:24 AM
SEFIxCivic's Avatar
Moroso oil pan when you start making big power @ WOT a lot of the oil actually gets stuck in the head and theres a good chance for oil starvation. That extra quart helps out.
Old Jan 17, 2002 | 09:40 AM
bigTom's Avatar
Default Re: things i should have added when i did my rebuild???? (SEFI8LOxCivic)
if its together or not... get a pro-drive oil gear!!!!! i couldnt stress this enough... as i have seen motors run good and then all of a sudden the oil gear shatters... basically ruining the entire motor! even if ur motor is together... i would take it out and change the gear
Don Jefe
Nov 8, 2012 03:39 AM
fin781
14
Mar 16, 2008 06:47 PM
sol2hatch
Mar 6, 2006 10:45 AM
Muckman
Jul 20, 2004 01:35 PM
BoostedH23a1
Oct 24, 2002 07:56 AM
