clunking noises while braking
Old Jan 16, 2002 | 11:11 PM
SwiftTypeR's Avatar
New User
Default clunking noises while braking
my car makes a loud sometimes faint clunk noise when i brake. does anyone knwo what the problem is and how i can fix it?
Old Jan 17, 2002 | 01:51 AM
SoCal ITR's Avatar
Default Re: clunking noises while braking (SwiftTypeR)
ABS? Is it on slick surfaces? Unless it happens all the time, then that's probably not it.
Old Jan 17, 2002 | 02:02 AM
SwiftTypeR's Avatar
New User
Default Re: clunking noises while braking (SoCal ITR)
happens everytime i brake....so its prob not the abs.
Old Jan 17, 2002 | 02:17 AM
SoCal ITR's Avatar
Sorry, wish I could help, just throwing an idea out there.
Old Jan 17, 2002 | 09:19 AM
Incognito's Avatar
Either your wheel lugs are loose, or your calipers/brake rotors are loose. happened to a friend's car recently. The back was making thumping noises while braking. One day the back left wheel just shot across the road.
Old Jan 17, 2002 | 09:48 AM
cobalt's Avatar
New User
Check caliper and make sure it's properly secured.
Otherwise...check wheel bearings.
Andie
Old Jan 17, 2002 | 09:54 AM
Willard's Avatar
torque your cv nuts.
I checked mine and after a quick torque session.. had a "clunk/pop" noise go away.
Will
-whos driver side was loose
Old Jan 17, 2002 | 11:26 AM
itr0045's Avatar
Default Re: clunking noises while braking (Willard)
I bet some of your wheel lug nuts are loose. My shop didn't tighten them after doing a valve adjustment right before I took a road trip down south. I was very lucky that I figured out the noise before a wheel fell off. They were that loose.
thekeysarebroke
Feb 18, 2013 12:42 PM
Mr.Chow
Oct 3, 2011 07:54 AM
jumpin4abeat
Aug 12, 2011 06:36 AM
TOO MUCH TORQUE
Sep 4, 2008 02:01 PM
