accord glow gauge Q
Old Feb 11, 2005 | 10:20 PM
Fook_me_honda's Avatar
Default accord glow gauge Q
Can anyone give me instructions on how to install these for a 1993 honda accord, the car has an airbag and i heard you have to remove the steering wheel to install the gauges, basically i just need SIMPLE* steps on removing and placing the gauges,
*I hate touching electronics (which is why i need simple steps) so please make them SIMPLE*
And no they are do not have that carbon fiber glow look to them
Old Feb 12, 2005 | 12:59 AM
iam7head's Avatar
Default Re: accord glow gauge Q (Fook_me_honda)
first thing first, you don't have to touch your airbag srs system to begin period.
take off the battery negative cable.
remove the bezel
unplug all harness until you can free the cluster
remove the cluster
take off the clear cover, and all plastic trim.
slip the guageface back on(some will snap right in but some you'll need some doube side tape)
the 12v power source you can just tap straight from your small light(the one on top of the cluster is the easiest) But the safest way to do it but it's the simplest.
put everything back in the same fashion.
Old Feb 12, 2005 | 01:51 AM
Default Re: accord glow gauge Q (iam7head)
Thanks, one more thing, if i unbolt the two bolts on the dash will the cluster fall out?
Old Feb 12, 2005 | 07:05 AM
Saturday Morning cartoon BUMP!
honda_accord_215
Jun 13, 2006 03:24 AM
aws140
Oct 30, 2005 09:44 AM
DelSolSi93
Mar 17, 2004 11:52 PM
ProjectXaccord
Nov 2, 2003 10:13 AM
Showoff
Apr 11, 2003 12:31 AM
