integra dash/EG question, i HAVE searched, this question is different and unanswered ;)
: Aight, so anyhow, i have a 95 integra dash with ALL the buttons/switchs AND the under dash wiring with connectors that plug into the fusebox. The blue and green plugs, plug right into the EG underdash fusebox, the grey one is slightly bigger. NOW, I HAVE SEARCHED and some other member asked a very similar question, but it was never answered...
If i cut off the grey integra larger plug from the underdash wiring, match the wires up to the smaller EG plug from the EG underdash wiring (which fits of course, duh) will it work? Or is there that same issue with the colors being different like how they are on the backs of the clusters? In searching i found out some of the wires are not consistant in their colors from one to another, but only in their location.
Thanks to all that let me know. If this works, it will make things a **** load easier. Even tho i enjoy a healthy challenge every now and again.
From: Why so you can pretend like youre interested, FL/OK
1994-97 is just about the same as 1992-95, so best suggestion to resolve is to actually pick up or request a wiring diagram with colors and functions for what you need. I'm sure being that there are different color plugs there are different locations for things, but the same functions are probably there. First, what is this grey plug harness for? That's what someone will need to know to be able to start somewhere. I would go as far to actually pose this question in the Integra forum, due to the fact you are going to want to find someone who actually has a manual.
Ls1 FD3s
Feb 12, 2005 09:45 AM
jdmcivicferio
Jun 25, 2003 02:24 AM
