integra dash/EG question, i HAVE searched, this question is different and unanswered ;)
Aight, so anyhow, i have a 95 integra dash with ALL the buttons/switchs AND the under dash wiring with connectors that plug into the fusebox. The blue and green plugs, plug right into the EG underdash fusebox, the grey one is slightly bigger. NOW, I HAVE SEARCHED and some other member asked a very similar question, but it was never answered...
If i cut off the grey integra larger plug from the underdash wiring, match the wires up to the smaller EG plug from the EG underdash wiring (which fits of course, duh) will it work? Or is there that same issue with the colors being different like how they are on the backs of the clusters? In searching i found out some of the wires are not consistant in their colors from one to another, but only in their location.
Thanks to all that let me know. If this works, it will make things a **** load easier. Even tho i enjoy a healthy challenge every now and again.
not to answer but im curious and want to do the same thing, did u cut a lot out of the dash to make it fit? did u remove the air duct of the EG? how about the door siding? sorry cant answer ur question. thanks
im pretty sure you can change the plug. match up the wires; but im not sure if colors are the same, use a wire list to exactly know
Ls1 FD3s
Feb 12, 2005 01:12 AM
jdmcivicferio
Jun 25, 2003 02:24 AM
