Replacing antenna mast but the antenna nut just spins in place!
Old Feb 11, 2005 | 04:46 PM
zak88lx's Avatar
Default Replacing antenna mast but the antenna nut just spins in place!
Hello,
I'm trying to replace my bent antenna mast with an oem replacement mast.
I have run into a problem, the antenna nut will not come off, it just spins in place like it's stripped.
What can I do?
Can I replace the antenna mast from below through the trunk?
Any ideas would be greatly appreciated.
Thanks,
Zak
Old Feb 12, 2005 | 02:20 PM
zak88lx's Avatar
Default Re: Replacing antenna mast but the antenna nut just spins in place! (zak88lx)
TTT
Old Feb 12, 2005 | 07:45 PM
Hondaaccordvtec's Avatar
Whats happening is the whole antenna body is turning in the trunk as you are turning the nut. I had this happen to me as well. Ended up dremeling the nut off and replacing the whole antenna mast and motor. A tip though - if you indeed replace the whole thing, when you screw on the new nut, place a little anti-seize of petro-jelly on the threads.
paniaguae640
Jul 27, 2009 08:28 AM
sobey
Mar 4, 2009 07:06 PM
prostreetonline
Jun 2, 2006 05:01 PM
prostreetonline
Nov 29, 2005 10:28 AM
SleepinGSR
Feb 27, 2002 02:03 PM
