door sagging
Old Feb 11, 2005 | 01:43 PM
itellyawhat's Avatar
Default door sagging
my drivers side door sags and hits the bottom when i close it. Those of you that have fixed this can you give me any tips? The only thing i can think of is to tight the 2 bolts on the door to the car. Thank you,
Jason
Old Feb 11, 2005 | 01:45 PM
turboLSef's Avatar
Default Re: door sagging (itellyawhat)
bump for answer.....Mine kinda do the same thing but not too bad... !?!
Old Feb 11, 2005 | 03:16 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: door sagging (turboLSef)
http://www.binghamtonlife.com/manual/2gsm/body.htm
under doors..20-7
Also,with the door open,Lift up on the outside edge,
The car itself should move not just the door..
If the door has excessive movement or play in the hinge,
the bushings in the hinge are probably worn out..
Old Feb 11, 2005 | 04:49 PM
thanks
Old Feb 11, 2005 | 05:44 PM
jisu009's Avatar
Default Re: (itellyawhat)
I just replaced the lower hinge on my drivers side door for the same reason....Make sure they are lubed up in there to prolong life...
Old Feb 12, 2005 | 01:37 PM
for those who haven't done this before I found that taking the fender off makes it a lot easier so you can get to the bolts and adjust it right then with out having to do guess work.
Old Feb 12, 2005 | 01:38 PM
ssl2k's Avatar
You just need to adjust them correctly, having the fenders off makes it a lot easier, do 1 at a time (either top or bottom mount) loosen one mount, have a friend pickup the door and hold it, then tighten it down...volia problem solved.
Old Feb 12, 2005 | 01:55 PM
mine are still not exactly right but i had to hurry. i reckon ill get em done tom. They are good up and down wise but left to right is off.
Old Feb 12, 2005 | 02:44 PM
DieMaster's Avatar
Needs to be About 20% Cooler
mine on the sedan sag alittle. say oh ~.5 inch but it's enough to hit the latch part. are my bushings bad?
Old Feb 13, 2005 | 01:43 PM
bushings? theres just a hinge that bolts the door to the car.
Old Feb 13, 2005 | 02:07 PM
88DXCRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">If the door has excessive movement or play in the hinge,
read much?
Yes, there are bushings inside the hinge which support the weight of the
door at its pivot points..
Old Feb 19, 2005 | 01:07 PM
lol ya i saw them the other day wen i finished. They are a little worn but it shuts nice now.
OsuSully
Mar 22, 2011 10:06 AM
crxsi8
Apr 8, 2005 04:04 PM
acourt
Nov 27, 2004 05:38 PM
jedubz
Feb 29, 2004 02:17 AM
PatrickGSR94
Feb 10, 2004 03:38 AM
