EK Side Skirt Install
Old Feb 11, 2005 | 12:29 PM
TedR719's Avatar
Default EK Side Skirt Install on EJ coupe
I've been searching throught the forums for a while now and I can not find the post where it shows you how to install the ek side skirts on an 94 ej coupe.
Can someone help me find that post, I belive I have to re-drill some holes and file them down to make a square to relocate the clips since they dont match up but just want to make sure before I go out and buy the wrong parts.
Old Feb 12, 2005 | 11:39 AM
TedR719's Avatar
Default Re: EK Side Skirt Install on EJ coupe (TedR719)
ttt
Old Feb 12, 2005 | 12:01 PM
b16ej1lsd's Avatar
you will need to redrill 4-5 holes, dont worry about making them square though, the clips will fit a round hole i believe. you will also have problems getting it to line up under the front fenders. i ended up making a pie cut in the end to allow the top of the sideskirt to go in farther and line up with the 5th gen fender and plastic welded it
Old Feb 12, 2005 | 03:19 PM
TedR719's Avatar
Default Re: EK Side Skirt Install on EJ coupe (b16ej1lsd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ej1lsd &raquo;</TD></TR><TR><TD CLASS="quote">you will need to redrill 4-5 holes, dont worry about making them square though, the clips will fit a round hole i believe. you will also have problems getting it to line up under the front fenders. i ended up making a pie cut in the end to allow the top of the sideskirt to go in farther and line up with the 5th gen fender and plastic welded it</TD></TR></TABLE>
plastic welded it? never heard of that
Old Feb 12, 2005 | 10:55 PM
TedR719's Avatar
anyone eles have some good info before i install them?
I heard that you dont need to cut the side skirt on the ej coupe, but there is a little extra skirt at the end but its not that bad and i'm very picky of just cutting it and just having it open at then end of the side skirt.
Old Feb 13, 2005 | 12:14 AM
vdub08's Avatar
cutting it isnt that bad, if you kno what you're doing. as i said in another thread, its pretty easy if you're proficient with a fine hacksaw or a bandsaw. its pretty easy to install, just drill new wholes and slap em on
and plastic welders can be bought or you can get a local exhaust place to weld something up.
Old Feb 13, 2005 | 01:07 PM
TedR719's Avatar
Default Re: (tofu9000)
anyone have pics of theirs installed?
jesimmers
Apr 7, 2007 05:36 AM
EKshin
May 19, 2006 06:29 PM
MidwestSi
Sep 15, 2005 06:58 AM
K-Bom05
May 8, 2003 09:25 AM
2000CX
Jan 14, 2003 06:04 PM
