Oil on spark plug
Old Feb 11, 2005 | 12:04 PM
peel17's Avatar
Default Oil on spark plug
Took off my spark plug wire and found oil on the thing that connects to the spark plug? Is that just a bad gasket O ring? Also theres oil coming out from the oil cap. wassups with that? is there something wrong?
Car is losing about 1 quart a week.
2000 LS 45k
Old Feb 11, 2005 | 12:22 PM
B20TDC2's Avatar
Default Re: Oil on spark plug (peel17)
if theres oil on theplug wire it would leave me to believe that its a tube seal but i dont know if thats your only problem if your losing a quart a week
Old Feb 11, 2005 | 02:40 PM
cnydc2's Avatar
The oil on the plugs is definatly a sigh of shot tube seals. Is the o-ring still on the oil cap? If not that would explain the leaking cap. A qt a week is a problem, is your oil pan gasket leaking? Honda oil pan gaskets are known to not seal properly and cause leaks.
teggyteg33
Mar 12, 2013 09:52 AM
VSM_EJ8_408
15
Jun 20, 2008 05:05 PM
jakscivic
Jan 31, 2007 06:11 PM
spartan6
Mar 3, 2006 09:36 PM
red civic standard
Jun 7, 2004 03:53 PM
