OK W T F my car is slower and slower, HELP me please!
Old Jan 16, 2002 | 08:27 PM
Bbasso's Avatar
Default OK W T F my car is slower and slower, HELP me please!
Heres the situation, I have now 22100 miles and it feels like its draging its ***.
its been getting slower ever since 14000 and I changed the plugs at 17000 and I do the oil every 2500 the air filter is clean and nothing else is shows up as worn or broken.
Could it be that the valves are way off?
What else could it be?
PS I had trouble blowing off a 4cyl accord he was 2 cars behind me and I was in 3rd gear I mean my foot was in the bumper I pressed so hard on the gas pedal and I went NO where. Now don't blame my driving skills, I know how to pass othere cars...
H E L P !!!
Old Jan 16, 2002 | 08:29 PM
Incognito's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (Bbasso)
Change your fuel filter. Advance timing. Also, do the valve lash adjustment. You can lose a LOT of power there.
Old Jan 16, 2002 | 08:30 PM
Bbasso's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (Incognito)
ok i did the gas filter at 12000
as for the valves who do you recommend, I'm not goin to the dealer (no clue)
Old Jan 16, 2002 | 08:31 PM
Mike K's Avatar
I've heard of cats clogging up due to a rich mixture.
THis happens over time of course.
Maybe 20hp loss... didnt someone here have the same situation?
Old Jan 16, 2002 | 08:32 PM
Bbasso's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (Mike K)
my plugs are very clean almost burning lean/ish
like I said I don't see anything to tip me off WHY...
Old Jan 16, 2002 | 08:35 PM
B2FiNiTY's Avatar
Spend some money and dyno it. Then you can really see if you losing power.
Old Jan 16, 2002 | 08:36 PM
junglistgsr's Avatar
you have 21k....and never done a valve adjustment? sounds like thats the problem...should be around $100 at the stealership...bit cheaper at other shops.
Old Jan 16, 2002 | 08:39 PM
Bbasso's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (B2FiNiTY)
Don't need to dyno, in the summer or second day at raceway i ran 14.7 and 14.8s at the end of the season the best i could get was 15.1 and 15.2
So i can see the diff and feel the differnce and its still stock.
I should try the vavles first and go from there?
Old Jan 16, 2002 | 08:44 PM
davidnyc's Avatar
I just got my valves adjusted....and the difference is definitely felt once I get into VTEC. I have almost 30K miles (yeh, I know I waited too long). But, the car is back to it's normal self now, fast !
Old Jan 16, 2002 | 08:46 PM
itr501's Avatar
I feel the same way but im only at 5500...haha.. man I'm really not use to revving high to get power.
Old Jan 16, 2002 | 08:47 PM
Bbasso's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (davidnyc)
really?, NICE to hear that.
I'll be doing a Vavle adj tomorrow!!!!!!!!
thanks David, glad I caught you.
and thanks to all too...
[Modified by Bbasso, 12:48 AM 1/17/2002]
[Modified by Bbasso, 12:49 AM 1/17/2002]
Old Jan 16, 2002 | 11:20 PM
o_Rage_o's Avatar
i'm assuming you also did the rest with the plugs too right? wires, cap rotor? my rotor had a small chip in it before and when i replaced it i got like 4mpg plus nice and free revving
Old Jan 16, 2002 | 11:25 PM
ITR 2K's Avatar
I had a similar situation. To me my car felt slower and slower, then after a while, I figured out it wasn't getting slower, it was just I got to use to it, and it didn't feel as fast as when I first got it.
Old Jan 16, 2002 | 11:49 PM
VaporTrail's Avatar
New User
check your throttle cable. If it's stretched or loosened, you may not be getting WOT.
Old Jan 17, 2002 | 12:25 AM
CheezeFrog's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (VaporTrail)
Have you ever bottomed out on anything? Might want to make sure there are no signifigant dents in yer exhaust system, which would rob power like crazy.
Old Jan 17, 2002 | 12:35 AM
Toda Party's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (CheezeFrog)
Hey Rob,
I'm getting my valve adjustment tools tommorow from my friend, and I should be able to do a Valve adjustment with u on Friday or Saturday if you'd like...let me know
jayhan925@aol. com
Old Jan 17, 2002 | 12:58 AM
kikkoboyie's Avatar
New User
Default Re: OK W T F my car is slower and slower, HELP me please! (Toda Party)
i know im stupid, what's a valve adjustment?
Old Jan 17, 2002 | 02:59 AM
citanest's Avatar
New User
Sorry for my ignorance, what is a fuel filter?
Old Jan 17, 2002 | 04:02 AM
Willard's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (kikkoboyie)
Valve adjustment info here... http://www.c-speedracing.com/howto/v...lveadjust.html
Fuel filter...
The black, round, metal item beside the battery. It traps "stuff" (trash/dirt) before it reaches the injectors.
Will
Old Jan 17, 2002 | 04:34 AM
Ex-ITR5874's Avatar
There can be another reason nobody thought of.
I felt the same and the power loss was caused by the oem cams.. they were ground in, at least 4mm (!).. The valves lost some percent lift ==> loss of power.
I highly recommend to check this out because the head can be totalled at least through this..
Old Jan 17, 2002 | 05:38 AM
i 4's Avatar
i 4
Default Re: OK W T F my car is slower and slower, HELP me please! (Maijk190)
Valve Adjustment is a must..get one every 12,000 miles or whenever they get loud.
Old Jan 17, 2002 | 05:42 AM
Cold Chunker's Avatar
Maybe he was squueezin y0!
Old Jan 17, 2002 | 08:16 AM
nEoMuGen's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (98ITR461)
David and Bbasso, please check our R-speed board and post somethine there! I asked the same question!
Old Jan 17, 2002 | 09:21 AM
SEFIxCivic's Avatar
The point of going on the dyno isn't really to tell how much power you have or don't have. I think that was suggested to you so that you can hook up a wideband to your tail pipe to see what kind of a/f mixture you're running. The torque curve will tell you a lot about what's going on with your motor. Another thing you can do it have your motor compression & leak down tested.
Old Jan 17, 2002 | 10:18 AM
GQ 05YellowEVO8's Avatar
Default Re: OK W T F my car is slower and slower, HELP me please! (SEFI8LOxCivic)
i do my own valve adjustments and tune ups. My buddy has that special Honda snap on tool for doing valve adjustments, it makes life much easier....
I can't wait till spring comes along, so I can do my summer time engine tune up, race preparation......
