98-01 Cluster into 94-97 Integra
Old Feb 11, 2005 | 04:31 AM
93civicsedan's Avatar
Default 98-01 Cluster into 94-97 Integra
Like the topic says I need to know how to get a 98-01 cluster to work in a 97 Integra. The plugs plug right into the cluster but the fuel gauge isnt working correctly. I goes all the way to F and then drops to E when driving. Also the seatbelt light doesnt come on. I searched but couldnt find which wires I need to change.
Old Feb 11, 2005 | 09:10 AM
SMZ GSR's Avatar
Default Re: 98-01 Cluster into 94-97 Integra (93civicsedan)
Easiest fix = Swap the green film on the back.
Old Feb 11, 2005 | 09:14 AM
calxtreme's Avatar
what is the difference between the two?
Old Feb 11, 2005 | 09:28 AM
greaseball's Avatar
Default Re: (calxtreme)
follow the wires behind each of the lights/gauges that aren't working. you need to swap the pins so they match up. i put a '95 cluster in my '99 and had swap a couple pins. it's easier to do than it is to explain it.
Old Feb 11, 2005 | 12:46 PM
Default Re: (greaseball)
thanks alot for the info. I went the easy route and just swapped the green film. everything is working
Wrona
Dec 26, 2011 08:19 PM
96 civic hatch
Aug 8, 2010 09:36 PM
Anticon1
Aug 22, 2006 06:21 PM
Joeyt426
Jul 22, 2006 03:48 PM
Itr001
Aug 24, 2005 11:31 AM
