Thread Pitch and Size of the banjo bolt at the fuel pump...
I need too know the Thread pitch and size of the banjo bolt that is off the fuel pump feed line.
I am going too run a ss line from the tank too the rail.
Thanks,
Bryson
Thanks,
Bryson
Well the part number for the 12mm bolt that goes into your fuel filer is the same as the part number for the 12mm bolt that goes into the fuel pump assembly. 90020-PD6-000 Is the p/n for the 12mm bolt that goes through the banjo fitting and washers.
So the pitch and size should be the same 12mm x 1.25
You're talking about # 5 in this pic right? That's what you're replacing with a SS line and fitting?
http://www.hondapartssource.co...ch=no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bryson »</TD></TR><TR><TD CLASS="quote">Yup...#5 is correct. Thanks a lot man!
NP dood
</TD></TR></TABLE>NP dood
