driveway, car makes noises
When I drive up my driveway, I go at an angle to prevent hitting it. So every time when I go up ( or same way back down ) I hear a noise that sounds like twisting? .. I cant tell or describe what the sound could be. But I know its coming from the back end of my car. So, I was just wondering if anyone else has this problem and was wondering how I could fix it. the only thing I can think of is geting a sway bar / lower strut bar installed
Also another thing. when Im going up drive ways like that, sometimes it feels like my rear right tire is running over something like a block. Its most deffinatly not the sidewalk, because im a good distance from it. Is that a suspension problem?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 »</TD></TR><TR><TD CLASS="quote">sounds like its the frame flexing</TD></TR></TABLE>
Bingo! I have to pull in and out of the driveway the same way as you. I've often wondered myself if a swaybar will do the trick. I can't afford one right now however. It's nothing to worry about. Get a swaybar and let me know how it works for you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimmyAtlantis »</TD></TR><TR><TD CLASS="quote">
Bingo! I have to pull in and out of the driveway the same way as you. I've often wondered myself if a swaybar will do the trick. I can't afford one right now however. It's nothing to worry about. Get a swaybar and let me know how it works for you.</TD></TR></TABLE>
Thats normal, a sway bar is gonna make you lift a wheel off the ground. which is not a problem.
type Gendy
59
Aug 10, 2006 11:48 AM
