Installed Eibach Sportlines with 5-perch Koni Yellows
Old Jan 16, 2002 | 06:52 PM
USteppin's Avatar
Default Installed Eibach Sportlines with 5-perch Koni Yellows
I just installed my suspension tonight, i set all the perches to the lowest settings, the back end is a 1 finger gap, the front end is at about 2 1/2 finger gap, should i wait like a month for the springs to settle before adjusting them again? or should i raise the back perches up 2 or 3 nothces?
Old Jan 16, 2002 | 07:09 PM
kikkoboyie's Avatar
New User
Default Re: Installed Eibach Sportlines with 5-perch Koni Yellows (USteppin)
i think you should wait for it 2 settle..... i have pro-kits on stock shocks, and my car sounds like it's about as low, if not lower than yours.
i saw pix of a teg w/ pro-kits and yello's on the lowest perch and it was lower than you described
jus give it some time to settle.
Old Jan 17, 2002 | 05:52 AM
maggsgsr's Avatar
Default Re: Installed Eibach Sportlines with 5-perch Koni Yellows (kikkoboyie)
I installed the sport lines with tokicos and it seems it took a week or 2 for them to settle.
Old Jan 17, 2002 | 07:28 AM
IndiEp's Avatar
Default Re: Installed Eibach Sportlines with 5-perch Koni Yellows (maggsgsr)
Hey - how do you like the Koni Yellows?
Old Jan 17, 2002 | 10:55 AM
USteppin's Avatar
Default Re: Installed Eibach Sportlines with 5-perch Koni Yellows (IndiEp)
the ride is great..
my question is though should i bother upping the perches on the back? or if the back is such a larger height difference than the front, are they gonna even out centered? cause theres a big gap difference
Old Jan 17, 2002 | 01:52 PM
Chicken SOup's Avatar
can we see some pics of the outcome?
Old Jan 17, 2002 | 03:08 PM
Warren's Avatar
Wrong-Way Wang
It's going to tag the bumpstops if you're that low. The Eibach sportlines are softer than my 400 lb/in up front, and I need to run a height of at least 25" from ground to top of wheel cutout.
You will hit the bumpstops at those heights. Just fyi.
Warren
Old Jan 17, 2002 | 03:10 PM
USteppin's Avatar
Default Re: Installed Eibach Sportlines with 5-perch Koni Yellows (Warren)
so i should move them up then? noones giving me a direct answer of what i should do..
ill try and get pics if i can
[Modified by USteppin, 12:13 AM 1/18/2002]
Old Jan 30, 2002 | 07:30 AM
Boosthead's Avatar
Front it higher than the rear? Did you check to make sure you didn't install the front perches on the Koni's incorrectly? I got in a hurry and did that once. Then again, maybe I'm just stoopid...
herrgolf
39
Aug 24, 2017 10:30 PM
integra-boy
Apr 11, 2007 03:35 AM
t_c_l_6
Suspension & Brakes
Mar 19, 2006 05:29 PM
Preludster
Nov 17, 2003 04:19 AM
