question about gsr axles
Old Feb 10, 2005 | 08:11 PM
boostin1cam's Avatar
Default question about gsr axles
will 94 gsr axles fit properly in my 93 civic coupe? i was talking to someone about this and they made it sound like they would't fit and there would be a problem with them being abs axles..but i'm wondering if i can put them with no problems? thanks guys
Old Feb 10, 2005 | 08:20 PM
jameskersten1's Avatar
Default Re: question about gsr axles (93civcoupe)
what motor are you using? if you have a b series motor then no problem but not with a d series.
as for the abs thing, i never had a problem with my gsr axles in my civic, so i assume it shouldnt be a problem.
Old Feb 10, 2005 | 08:23 PM
numbnuts22715's Avatar
Default Re: question about gsr axles (jameskersten1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jameskersten1 &raquo;</TD></TR><TR><TD CLASS="quote">what motor are you using? if you have a b series motor then no problem but not with a d series.
as for the abs thing, i never had a problem with my gsr axles in my civic, so i assume it shouldnt be a problem.</TD></TR></TABLE>
yep, hes correct, They will fit only if you have a B series engine in your civic. If its the stock civic engine, then it will not fit.
i'm using a 94 gsr motor, i'm getting everything for it out of a wrecked 94 gsr. thanks man i appreciate the help
Old Feb 10, 2005 | 08:32 PM
htec17's Avatar
the axle fit . The abs ring does notthing. and is not in your way.
aight, then theres no problem, theyll work fine. that thing is gonna haul ***.
Old Feb 10, 2005 | 08:35 PM
Default Re: question about gsr axles (numbnuts22715)
thanks guys i really do appreciate the help
honda305
Nov 30, 2008 11:48 PM
kartman
Sep 14, 2005 07:08 PM
b18c inside
May 4, 2005 06:38 AM
deviant1
13
Mar 7, 2005 07:33 AM
Rodney
Apr 7, 2004 02:17 AM
