Question about the D16y7
Old Feb 10, 2005 | 07:16 PM
sd.coupe's Avatar
Default Question about the D16y7
thinkin of getting this motor from someone off h-t for pretty cheep.... would be going into a 90STD hatch... pros? cons?... never heard of y7 whats the diff between y7 & 6 for the ef?
Old Feb 10, 2005 | 07:22 PM
svivanh's Avatar
Default Re: Question about the D16y7 (sdhatch)
Old Feb 10, 2005 | 07:34 PM
crxnj's Avatar
Default Re: Question about the D16y7 (svivanh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdhatch &raquo;</TD></TR><TR><TD CLASS="quote">thinkin of getting this motor from someone off h-t for pretty cheep.... would be going into a 90STD hatch... pros? cons?... never heard of y7 whats the diff between y7 & 6 for the ef? </TD></TR></TABLE>
The d16y6 is vtec
D16y7 is not
Old Feb 10, 2005 | 07:36 PM
sd.coupe's Avatar
can u make it y6 or does that not have to do with any vtec stuff?
Old Feb 10, 2005 | 07:43 PM
crxnj's Avatar
Default Re: (sdhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sdhatch &raquo;</TD></TR><TR><TD CLASS="quote">can u make it y6 or does that not have to do with any vtec stuff?</TD></TR></TABLE>
First of all Ive never seen a d16y6 motor in this country..I seen some back in my home country of barbados..Some in Jamaica..Some in Australia..Never seen that motor in this country before..
If you want to convert the d16y7 to vtec all you have to do is get a d16y8 or d16z6 head(These motors are more easy to find then the d16y6)..and remove the oil jet on the block..Then wire up vtec
Old Feb 10, 2005 | 09:12 PM
colinproctor's Avatar
Default Re: (Mr.speaker)
i have a d16y7 for sale. check sig.
Old Feb 10, 2005 | 10:51 PM
aaronhume's Avatar
Default Re: (FdOoUoRr)
actually the d16y7 has vtec-e which turns off an intake valve on each cylinder when it turns on so as to swirl the air inside the combustion chamber, to save on gas. its got 115 hp. I would highly recommend going with a different swap if you want power.
sce310
Honda Civic (2006 - 2015)
32
Nov 4, 2006 07:33 PM
TougeMonkey
Jan 19, 2006 08:01 PM
Suck my DX
Apr 12, 2005 06:03 PM
explictness
10
Aug 29, 2004 02:57 PM
krazie1
12
Oct 28, 2003 03:54 PM
