Code 4 on B16 please help.
Old Feb 10, 2005 | 06:13 PM
c_buz's Avatar
Default Code 4 on B16 please help.
I am throwing a code 4 on my 88 Civic Hb with a b16. The fires up fine but it won't go pass three grand and runs like absolute crap. Like it's lacking power. I haven't driven it I just tested it on neutral. What does code 4 stand for. I heard it's cps and someone said something about replacing the whole dizzy. Any help is appreciated.
Old Feb 10, 2005 | 06:16 PM
HatchBox's Avatar
Skoobie no more...
Default Re: Code 4 on B16 please help. (c_buz)
Old Feb 10, 2005 | 06:29 PM
c_buz's Avatar
Default Re: Code 4 on B16 please help. (HatchBox)
OK I'll have to check my dizzy then. Do you know if a B18b1 dizzy will work on a b16a
Old Feb 10, 2005 | 06:32 PM
HatchBox's Avatar
Skoobie no more...
yes
Old Feb 10, 2005 | 06:37 PM
c_buz's Avatar
i am leaning towards a bad ecu however. My ecu just burned one of the circuits and I bridged the burnt part with a wire. Car was running perfect before this so I will first replace my ecu before I eve check the dizzy.
Old Feb 19, 2005 | 07:45 PM
92HB_HB's Avatar
where does b10 and b 12 run to in the engine bay ?? i checked the resistance there and got no resistance..
this is on my 94 gsr turbo.. and its getting frustrating..
Old Feb 20, 2005 | 03:13 AM
Beyond Imagination's Avatar
my car started throwing a code 4 when the weather got cold. exact same problem where it would run and idle fine until hitting 3000rpm. i ended up replacing the brand new dizzy which was under warranty and it runs fine now. good luck.
Old Mar 1, 2005 | 07:05 AM
PreludeSiTdriver's Avatar
Default Re: Code 4 on B16 please help. (Beyond Imagination)
what is the dizzy? I see this and dont know what it is. thanks
Old Mar 1, 2005 | 07:09 AM
d16efsedan's Avatar
Default Re: Code 4 on B16 please help. (PreludeSiTdriver)
a 'dizzy' is a distributor i had to ask the same thing when i started on here
Old Mar 2, 2005 | 05:09 PM
Default Re: Code 4 on B16 please help. (d16efhatch)
i was kinda thinking it was but didnt want to look stupid. Guess i do now though oh will i got the facts lol. Well on the subject, my dizzy went bad on me. I am wondering if that is what was causibg my dyno runs to be shitty.
Old Mar 6, 2005 | 01:23 PM
well swapped my dizzy out with a new one from my friends car and it did not take the code away. swapped ecus with his and it ran fine. what can it be my ecu?
gsrpowercrx
Aug 2, 2008 11:44 AM
1990hondaHF
Aug 5, 2007 12:58 PM
integra95gsr
May 9, 2006 06:22 PM
crxtreme27
Feb 4, 2004 10:19 PM
