stock flywheel weight
Old Feb 10, 2005 | 05:31 PM
18gLUDE's Avatar
Default stock flywheel weight
i just bought a lightweight flywheel but i haven't installed it yet. i weight it and it is 12.5 lbs. it was advertised as 10.5lbs on ebay. but anyway, does anyone know the weight of a stock h22 flywheel?
Old Feb 10, 2005 | 06:02 PM
bb6h22a's Avatar
Default Re: stock flywheel weight (18gLUDE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 18gLUDE &raquo;</TD></TR><TR><TD CLASS="quote">i just bought a lightweight flywheel but i haven't installed it yet. i weight it and it is 12.5 lbs. it was advertised as 10.5lbs on ebay. but anyway, does anyone know the weight of a stock h22 flywheel?</TD></TR></TABLE>
Mine weighted 18.9 lbs when I replaced it with an 8lb fidanza.
Old Feb 10, 2005 | 06:41 PM
lakerschamp2000's Avatar
12.5 lbs is perfect for your h22. too light like 8lbs it drop like a **** and is not good for your engine.
Old Feb 10, 2005 | 07:39 PM
Mike95lude's Avatar
I weighed mine in at exactly 20 lbs.
Old Feb 10, 2005 | 09:09 PM
Shakes's Avatar
space cadet
Default Re: stock flywheel weight (Mike95lude)
mine pulled in at 27 pounds
Old Feb 10, 2005 | 09:16 PM
SKDRCR's Avatar
Default Re: stock flywheel weight (Shakes)
I wonder how much weight it takes off when you resurface the flywheel?
I'm guessing about a 1/4 lb or so
Old Feb 10, 2005 | 11:09 PM
revlimitx04's Avatar
Default Re: stock flywheel weight (SKDRCR)
12.5 should be dandy.
Old Feb 11, 2005 | 05:06 AM
AndyD's Avatar
Default Re: stock flywheel weight (lakerschamp2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lakerschamp2000 &raquo;</TD></TR><TR><TD CLASS="quote">
12.5 lbs is perfect for your h22. too light like 8lbs it drop like a **** and is not good for your engine.</TD></TR></TABLE>
No it's not.
Don't listen to dudes like this. Comments like this made me worried about getting an 8lb flywheel. Now that I have it, I consider it the perfect weight. The RPMs don't drop as fast as these dudes say. THe rpms drop enough to make shifting easier.
It doesn't even make everyday driving any harder.
Old Feb 11, 2005 | 07:32 AM
18gLUDE's Avatar
Default Re: stock flywheel weight (AndyD)
thanks for all the reply's. how come there is such a big difference in people's stock weights. we have 18.9lbs, 20lbs, and 27lbs? thanks again fellas.
Old Feb 11, 2005 | 08:00 AM
PrettyLude's Avatar
what kinda flywheel did you buy? i never seen a 12.5 lb flywheel before.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">No it's not.
It doesn't even make everyday driving any harder.</TD></TR></TABLE>
i have one too, i don't see anything also that would make it harder to drive everyday
Old Feb 11, 2005 | 08:50 AM
getnasty's Avatar
Default Re: stock flywheel weight (PrettyLude)
I love my 8lb fidanza. and my stocker weighed at 18.5
Old Feb 11, 2005 | 09:09 AM
Ministry's Avatar
Default Re: stock flywheel weight (bottle fed)
Anyone that cries about RPM dropping to quickly with an 8 lb flywheel needs to consider learning to drive. Seriously, that claim holds about as much water as the "H22 is too heavy to go in a civic" myth. I am no Petter Solberg, and I have no problem shifting quickly with my fidanza flywheel, and I drive my car every day in traffic.
My stocker was around 19 lbs
Old Feb 11, 2005 | 09:17 AM
98TypeSH's Avatar
Default Re: stock flywheel weight (dreamer)
Here is the difference.
It is recommended to go with 8lbs for road racing/ auto cross. It enables you to have more control over the engine rpms and your shift points. 12.5 and up is recommended for Drag racing and normal daily driving. You want more rotating mass as to get as much power to the ground as possible in a drag racing situation. If you have a high HP drag monster with an 8lbs flywheel, im willing to bet you may have some traction problems as well as the RPMs dropping very rapidly during upshifts. thats my logical explanation.
Old Feb 11, 2005 | 10:00 AM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrettyLude &raquo;</TD></TR><TR><TD CLASS="quote">what kinda flywheel did you buy? i never seen a 12.5 lb flywheel before.
my 12.5 lb is a clutchmasters.
Old Feb 11, 2005 | 10:30 AM
Default Re: stock flywheel weight (98TypeSH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98TypeSH &raquo;</TD></TR><TR><TD CLASS="quote">Here is the difference.
It is recommended to go with 8lbs for road racing/ auto cross. It enables you to have more control over the engine rpms and your shift points. 12.5 and up is recommended for Drag racing and normal daily driving. You want more rotating mass as to get as much power to the ground as possible in a drag racing situation. If you have a high HP drag monster with an 8lbs flywheel, im willing to bet you may have some traction problems as well as the RPMs dropping very rapidly during upshifts. thats my logical explanation.</TD></TR></TABLE>
Old Feb 11, 2005 | 11:09 AM
Civic H22's Avatar
my h22 flywheel weight 18.65 LBS.
Old Feb 11, 2005 | 11:42 AM
bb6h22a's Avatar
Too bad it makes no sense.
Rething your "logic" for a second.
Old Feb 11, 2005 | 12:21 PM
bad-monkey's Avatar
Default Re: stock flywheel weight (bb6h22a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bb6h22a &raquo;</TD></TR><TR><TD CLASS="quote">
ugh, i smell an angular momentum problem...as well as a strength of materials problem...
problem is, i'm gonna get curious about this question and start drawing free body diagrams
CTGrey06RSX-S
Jan 11, 2008 06:16 PM
hndah8er84
Honda S2000
Apr 3, 2007 09:20 AM
ajbucci
May 20, 2006 09:39 AM
AlienKrOZ
May 20, 2004 08:10 PM
Jago
Sep 22, 2003 04:41 AM
