PM8/PR4 and Code 13
Old Feb 10, 2005 | 02:58 PM
AR Fab's Avatar
Default PM8/PR4 and Code 13
Alright...heres the issue....we put in a SOHC ZC in a CRX HF
On the stock HF PM8 we have no code 13
Put the first PR4 in code 13....
So we took out a known good PR4 from a running car....code 13
Any thoughts?
It runs great with the CEL on...lol...but im not the kind of person to pull the CEL light out....
Howard
Old Feb 11, 2005 | 09:20 PM
1QwIkEf's Avatar
From: R.I.P Brian Arbogast...you will be missed, maryland, USA
Default Re: PM8/PR4 and Code 13 (AR Fab)
howard ... try this.. unplug the backup lights at the tranny and reset the ecu but let the lights unpluged try it.....no j/k had the same prob with my 89 crx HF with b16 PR3 tho..
Modified by TURBO BLUE HATCH at 3:10 PM 2/12/2005
Modified by TURBO BLUE HATCH at 12:15 AM 2/13/2005
Old Feb 11, 2005 | 09:59 PM
davens's Avatar
Are you 100% sure on your wiring?
There are some minor differences with the HF and Si harness(like the some EGR and tranny pins). Sorry to be presumptious, but some people assume the HF is a plug-and-play copy because its already MPFI.
Old Feb 12, 2005 | 09:45 AM
CivicRaping's Avatar
i had teh same exact problem in my sohc zc code 13 is the atmospheric pressure sensor check that little black sensor near the glove comaprtment if its a bad sensor or check the ecu wiring that was my problem
Old Feb 12, 2005 | 05:02 PM
AR Fab's Avatar
Default Re: PM8/PR4 and Code 13 (CivicRaping)
Fixed.....we had the inccorect ECU....the ones we had, have the Baro sensor onboard..but our car had a BARO on the fire wall....so It gave us the code...
Howard
88crxhfzc
Feb 1, 2010 12:08 AM
SexyAzNMami
11
Feb 25, 2005 05:28 PM
chirp2hrd
Jun 16, 2003 06:47 PM
pdiddyparsons
Apr 16, 2003 07:07 PM
