B16 Crx Clutch Probs.
Well i finally finished my swap, everything was cool until something had to go wrong. When i got my motor from Hmotors i checked the clutch disc and it looked fine to me, almost as good as a new i have the pressure plate had some Throw out bearing wear but still looked fine the throw out bearing looked a little wore out. So i decided it will still worked. put the motor and tranny together and today that dam thing wont go into gear. the only way it will go into gear is if i turn off the car put in gear and it goes but I dont have a clutch watsoever.
can anyone help me out. i have a new clutch press plate and thro out bearing. sitting here should i slap it on? or could there be something else wrong.
fminusmic
14
Feb 1, 2022 05:07 PM
