When changing tranny fluid...
Old Jan 16, 2002 | 05:43 PM
Toda Party's Avatar
Default When changing tranny fluid...
Well, i changed the tranny oil today...it was pretty clean (13,740 miles)...anyway, when I was filling it back up, i couldn't really see if it was even will the fill hole or not, so i just kept filling till some started overflowing...
Then I realized, it started overflowing with only 2 quarts...i didn't know what to do so i put in a little more of the 3rd quart, then stuck the bolt back in
its ok to have a little more than what's listed right? (its not like I used a whole extra quart, i put in just a bit more...)
I'm assuming its like when you change your motor oil, theres a little in the motor so it wont take the full 4.xx quarts...
Old Jan 16, 2002 | 05:54 PM
MrBite's Avatar
Default Re: When changing tranny fluid... (Toda Party)
how was your car jacked up? was it just the front? When I did mine I had the back slightly higher than the front so it all went in. You might want to do this just to top it off (yeah I know, pain in the butt ). How did you get at that fill hole? I had to use a hand pump thingie that my friend had.
Old Jan 16, 2002 | 05:57 PM
JohnnyBoy's Avatar
Default Re: When changing tranny fluid... (MrBite)
Make sure the car is level....Also it may squirt some out after the 1st or 2nd bottle. It is not full however...Let it sit for a minute then keep filling until it comes out consistantly...Then you should be o.k.
Old Jan 17, 2002 | 12:31 AM
Toda Party's Avatar
Default Re: When changing tranny fluid... (JohnnyBoy)
yeah i figured since it was jacked up, it'd be off...i just poured it till it started running out a good bit, and plugged it...next time i'll have to put it evenly on jackstands...
i used this funnel with a long tapered tube that fit snugly inside the fill hole....basically resembled a beer funnel, except tapered at the end...worked nice, got it at pep boys
jdmblu3s
14
May 21, 2007 05:55 AM
dk127
Mar 27, 2004 02:35 PM
98GeeYes-Are
Mar 21, 2003 11:28 AM
gsxr
Apr 6, 2002 02:44 PM
