timing belt
Old Feb 10, 2005 | 12:49 PM
Kashi's Avatar
Default timing belt
does anyone know if the timing belts for USDM and JDM are the same? i called my honda dealer for a new timing belt, and they said that their computers don't show whether it's for US or JDM versions, only the basic stats- 93 prelude VTEC. can anyone help me with some info? also, they said it costs $63.33. is that about right? my engine is an h22a1. thanks!
Old Feb 10, 2005 | 12:51 PM
The Phil's Avatar
Default Re: timing belt (Kashi)
you're in the states, and you drive the h22a1, a USDM motor. It's the right one whether or not they are interchangeable.
Old Feb 10, 2005 | 01:23 PM
Kashi's Avatar
Default Re: timing belt (xthephilx)
the h22a1 is a usdm? i seriously did not know that. i thought the h22a series, whether it had numbers after it or not, were jdm. i'll be damned... but, if it is the right one, then my question is answered. thanks!
Old Feb 10, 2005 | 02:03 PM
LudaMan's Avatar
Look what I can do!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kashi &raquo;</TD></TR><TR><TD CLASS="quote">the h22a1 is a usdm? i seriously did not know that. i thought the h22a series, whether it had numbers after it or not, were jdm. i'll be damned... but, if it is the right one, then my question is answered. thanks! </TD></TR></TABLE>
the H22a is the JDM motor and the H22a1 and a4 (for 5th gens) are USDM
Old Feb 10, 2005 | 02:58 PM
Kashi's Avatar
Default Re: timing belt (LudaMan)
ahhh. so should i order a timing belt for the 4th gen or the 5th gen? does it even matter?
Old Feb 10, 2005 | 04:08 PM
The Phil's Avatar
Your car is a 93, so its a 4th gen. Order that one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudaMan &raquo;</TD></TR><TR><TD CLASS="quote">
the H22a is the JDM motor and the H22a1 and a4 (for 5th gens) are USDM</TD></TR></TABLE>
Old Feb 10, 2005 | 09:36 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kashi &raquo;</TD></TR><TR><TD CLASS="quote">ahhh. so should i order a timing belt for the 4th gen or the 5th gen? does it even matter?</TD></TR></TABLE>
Order the one for the 4th gen vtec (h22a1).
Old Feb 10, 2005 | 11:05 PM
revlimitx04's Avatar
Default Re: timing belt (SKDRCR)
Well prostreet online makes timing belt kits, that come with a water pump, balancer belt, tensioner and the timing belt. 300 bux.
Id do your waterpump while your down there definatly.
Old Feb 11, 2005 | 03:32 AM
Kashi's Avatar
Default Re: timing belt (revlimitx04)
sure thing. thanks, guys!
i swear, is everyone on here a mechanic? a specialized mechanic? i'm learning a lot, for sure, but how does everyone know all this?
Old Feb 11, 2005 | 05:17 AM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revlimitx04 &raquo;</TD></TR><TR><TD CLASS="quote">Well prostreet online makes timing belt kits, that come with a water pump, balancer belt, tensioner and the timing belt. 300 bux.
Id do your waterpump while your down there definatly. </TD></TR></TABLE>
No, don't buy the kit. If I were someone replacing the timing belt, I would do all of the following at the same time.
I would:
Change the timing belt and balancer belt
Swap to a 92-96 H23 manual timing belt tensioner
Change the water pump
Old Feb 11, 2005 | 08:15 AM
PrettyLude's Avatar
autotensioner=junk
Old Feb 11, 2005 | 08:27 AM
Kashi's Avatar
Default Re: timing belt (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">
No, don't buy the kit. </TD></TR></TABLE>
i couldn't afford that kit if i wanted to. college student barely able to afford this maintenance as it is. i need to go to honda today to pick up a belt and a gasket to bring to my mechanic on monday. thanks, though
Old Feb 11, 2005 | 09:40 AM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kashi &raquo;</TD></TR><TR><TD CLASS="quote">sure thing. thanks, guys!
i swear, is everyone on here a mechanic? a specialized mechanic? i'm learning a lot, for sure, but how does everyone know all this? </TD></TR></TABLE>
The more you lurk teh Almighty Prelude forum, the more you will learn
You should do the water pump/man tens. conversion as well.
whyS0serious
May 11, 2012 05:33 PM
EKHWhat
Mar 7, 2007 06:52 PM
h22lude619
Apr 18, 2006 07:10 PM
Micky
Feb 17, 2004 03:37 PM
