Sparco Racing Harnesses on Stock GSR SEats?
BSQ
do you autox or anything? .. your 5 pt harness looks great but do you really need it? what about rear seats? noone sits there?
[Modified by Supadoggie, 9:47 PM 1/17/2002]
Please don't run harnesses on a car without a rollbar.... if you roll you will die because your head will be suporting the roof.
at least the oem seats will collapse in a crash if the roof caves in....
even 5 pt harnesses wont hold you up if the oem seat collapses...
I hear ya though.
BSQ
My 5-point harnesses are attached to a custom harness bar which attaches to the rear upper seatbelt points. The harness bar can be easily bolted in approx. 5 minutes; therefore, I only use it for HPDE.
I run 5 pts with the stock GSR seat and it works okay. The bigest issue is the antisub belt. It should really come up close to your crotch. With the stock seat it is out front and pulls the belts away from your body a bit.
Now, this is VERY dangerous and a big no-no in my book.
[Modified by BSQ, 7:07 PM 1/17/2002]
Can you give more detail as to why this is a "big no-no" in your book? You mentioned that you are using 5-point harness, so can you comment on how you attach yours?
This topic has come up many times in both the Competition and ITR forums. Do a search and you will find most people feel the same way I do.
In my case, I have a 4 point roll bar.
Wow Bret. Your site is great, quick-snappy-and right to the point.
Incredible mods and instructions.
HondaRcB
23
Jul 20, 2006 06:22 AM
