HELP!!!Rev probelm
Old Feb 10, 2005 | 10:14 AM
demdem's Avatar
Default HELP!!!Rev probelm
I have a problem with a D15 engine the rev keep going up and down could u give me idea whats going on with it
Old Feb 10, 2005 | 11:33 AM
primeredbeast's Avatar
Default Re: HELP!!!Rev probelm (demdem)
try to clean out the iacv on the back of the intake manifold it's a little black thing with 2 bolts or so holding it on take the bolts off and spray some carb cleaner on the screen
Old Feb 10, 2005 | 04:27 PM
PrettyLude's Avatar
Default Re: HELP!!!Rev probelm (primeredbeast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by primeredbeast &raquo;</TD></TR><TR><TD CLASS="quote">try to clean out the iacv on the back of the intake manifold it's a little black thing with 2 bolts or so holding it on take the bolts off and spray some carb cleaner on the screen</TD></TR></TABLE>
also it could be the fitv, vacuum leaks, air bubbles in your coolant
Old Feb 10, 2005 | 04:52 PM
demdem's Avatar
what is FITV could u explain where it is located and what is the perpose of it
Old Feb 10, 2005 | 09:43 PM
PrettyLude's Avatar
fitv=fast idle thermo valve
its directly underneath your throttlebody with the coolant lines running thru it.
its purpose is to sense the temperature of the coolant and adjust the idle accordingly
Old Feb 11, 2005 | 04:52 AM
demdem's Avatar
Default Re: (PrettyLude)
Thanks much for the help people
jb0705
10
Aug 30, 2009 02:13 PM
cleanej2
13
Feb 13, 2008 07:50 PM
h23a1pimp
Dec 6, 2005 04:08 PM
bleedblue94
Dec 2, 2004 06:38 PM
gtowni3
Jun 15, 2004 01:30 PM
