Oil return line, I made a mistake..
Old Jan 16, 2002 | 04:49 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Oil return line, I made a mistake..
I told everyone the wrong part on 2 things.
First was the the 1/2 to -10 fitting, I said 3/8 to -10 and I was wrong there.
The other was the steel weld fitting, get brass for the oil pan.
I just installed a turbo kit on a ITR and I took some pics of the oil return line: http://www.turbomafia.com/Arturbo/bobby/fittings.jpg http://www.turbomafia.com/Arturbo/bobby/fittings2.jpg http://www.turbomafia.com/Arturbo/bobby/fittings3.jpg http://www.turbomafia.com/Arturbo/bobby/fittings4.jpg http://www.turbomafia.com/Arturbo/bobby/fittings5.jpg http://www.turbomafia.com/Arturbo/bobby/fittings6.jpg http://www.turbomafia.com/Arturbo/bobby/fittings7.jpg http://www.turbomafia.com/Arturbo/bobby/fittings8.jpg
art
Old Jan 16, 2002 | 04:56 PM
JM Performance's Avatar
Default Re: Oil return line, I made a mistake.. (Arturbo)
How is that fitting in the pan? Welded on the inside? Or just tapped?
stick's Avatar
damn that is a good job on the oil plug fitting on the oil drain
also looks like a really good install.
u guys should be finised today for sure
BTW, i got some leads on some parts out in Ft. Worth. all the parts i need basically.
gotta go check them out on tuesday.
Old Jan 16, 2002 | 05:00 PM
Flamenco-T's Avatar
huh ?
it was a 1/2 to -10 right ?
you need sleep..heheheheh
Old Jan 16, 2002 | 05:14 PM
Mikex25's Avatar
New User
Default Re: Oil return line, I made a mistake.. (Flamenco-T)
how bad is it to use a steel weld fitting?
Old Jan 16, 2002 | 05:18 PM
b18bvudoo's Avatar
New User
kinda looks like that oil line is running up near the pan, but maybe its the angle of the shot.
Old Jan 16, 2002 | 05:22 PM
falcongsr's Avatar
What is this crap?
Default Re: Oil return line, I made a mistake.. (00SilverLS)
he said it was brass and it was welded on the inside
Old Jan 16, 2002 | 05:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Oil return line, I made a mistake.. (falconGSR)
Also, those pics are not the final results. I had to fix the hose so it was facing more down so the oil wont get blocked.
art
Old Jan 16, 2002 | 06:24 PM
Mikex25's Avatar
New User
on the picture the weld fitting looks like steel, is that correct?
Old Jan 16, 2002 | 06:40 PM
shingles's Avatar
Art,
On the oil return flange, where was that piece from? MaxRev?
thanks,
-Shing
Old Jan 16, 2002 | 07:08 PM
93LSivic's Avatar
Lookin good Art ! I think I'm gonna do mine with 2 90 degree hose ends.
Nice overspray on the lower rad support!
Old Jan 16, 2002 | 07:10 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Oil return line, I made a mistake.. (shingles)
Mikex25, in the 1st pic it is aluminimum. I didnt take a pic of the weld fitting that we used but it is brass.
shingles, I buy and have them made locally for me.
But Max-rev is a good piece aswell.
art
Old Jan 16, 2002 | 07:28 PM
shingles's Avatar
art
got any for sale?
Old Jan 16, 2002 | 08:19 PM
dustin's Avatar
Sure it is brass art? All the ones I found were brass colored with a brass coating, but they were mild steel underneath.. we brazed mine to my oil pan.
Dustin
Old Jan 16, 2002 | 08:31 PM
Flamenco-T's Avatar
Default Re: Oil return line, I made a mistake.. (93LSivic)
I wouldn;t get a 90 deg hose end...you'll better off with 45 deg, I hade leaks with 90 deg, better luck with 45 deg....just angled it right, to where it goes down...
stan
Old Jan 16, 2002 | 08:51 PM
TheShocker's Avatar
Nice job
Old Jan 16, 2002 | 11:48 PM
lucas569's Avatar
thanks alot,i did a search the other day and found the part #'s for all those fittings,etc... now i gotta start all over again!
Old Jan 17, 2002 | 12:48 AM
degradated's Avatar
New User
Why do you recommend brass over steel for the fitting? My experiences have been that brass is much harder to work (weld) with, and it ended up costing me the price of a new oil pan to find out.
Old Jan 17, 2002 | 12:58 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Oil return line, I made a mistake.. (degradated)
Well according to dustin its steel but a brass color or coating. It want very hard to weld so maybe it was steel.
art
Old Jan 17, 2002 | 05:08 AM
jamal-188's Avatar
Looks really nice, how much do you want to make me on?!?!
Old Jan 17, 2002 | 06:24 AM
SiR Kid's Avatar
New User
Default Re: Oil return line, I made a mistake.. (jamal-188)
Here's what we did on my oilpan, just a suggestion for the people ot there without welders...
We went to the local high pressure fitting store and picked up a screw together bulkhead. Along with thick nylon washers/grommets it sealed tight inside and outside the oilpan. No chance of slag, leaks or ugliness. It was really a nice fit, and was only about $20 for the whole conglomoration.
I'll try to get pics once I borrow my brother's digital camera again.
Old Jan 17, 2002 | 06:53 AM
lucas569's Avatar
Default Re: Oil return line, I made a mistake.. (SiR Kid)
high pressure fitting store? wish we had one here... what ws the name of the store?
Here's what we did on my oilpan, just a suggestion for the people ot there without welders...We went to the local high pressure fitting store and picked up a screw together bulkhead. Along with thick nylon washers/grommets it sealed tight inside and outside the oilpan. No chance of slag, leaks or ugliness. It was really a nice fit, and was only about $20 for the whole conglomoration.I'll try to get pics once I borrow my brother's digital camera again.
Old Jan 17, 2002 | 10:41 AM
turbosol's Avatar
Default Re: Oil return line, I made a mistake.. (lucas569)
NAPA has those parts, I did the same thing with the bulkhead fittings and it hasn't leaked yet.
Damian
Old Jan 17, 2002 | 10:48 AM
dustin's Avatar
Brass is tough to weld....
Old Jan 17, 2002 | 10:53 AM
b18bturbo's Avatar
Default Re: Oil return line, I made a mistake.. (dustin)
aluminum is tough to weld. Brass is fairly easy compared ot that damn aluminum it starts metling and stuff
