Another question on a Honda Hatchback 1.5L upgrade
Old Feb 10, 2005 | 07:51 AM
Escaflowne's Avatar
Default Another question on a Honda Hatchback 1.5L upgrade
I was wondering how much more horsepower would I get, <U>without</U> doing an engine swap, just add a new air intake, headers and sport exhaust, and possibly a chip? I'm not looking to race ...just trying to get a little more bang for my buck.
Old Feb 10, 2005 | 07:54 AM
EP3_05's Avatar
Default Re: Another question on a Honda Hatchback 1.5L upgrade (Escaflowne)
Best bang for the buck is swapping to mpfi. The 1.5L does not respond to bolt ons very well. Swap to mpfi and then add i/h/e and a chip.
Old Feb 10, 2005 | 08:04 AM
PHOBIA's Avatar
adding a chip wont really do anything oter than make you run rich.i would do the mpfi swap and then spend the rest on suspension upgrades, then build a low budget turbo setup.
Old Feb 10, 2005 | 08:13 AM
CivicHB89's Avatar
Hey man im in your same position. I dont have much cash but wanted a lil more power. Im doin the MPFI swap right now. So far ive spent about $100 on it, and all i still need to get is the distributor, resistor box, and pm6 ecu. So pretty cheap for some small power. PM me if you need any help getting started.
Edit: Forgot your trial user, cant PM yet, email me if you need help getting started, cslax88@rochester.rr.com
Old Feb 10, 2005 | 08:32 AM
ssl2k's Avatar
You will notice the most out of the MPFI swap...
Other than that, I personally wouldn't waste the money on a i/h/e rather for the cost of a decent header, intake and exhaust you coudl put togethre an ok HMT setup. (you can flat rate **** and get by wtth it at about 400bucks for a turbo kit.
That'll give you your best bang for buck imo.
otherwise, You can do a mini me onto the 1.5L block w/ a z6 or y8 head and gain a little more power if you dont want to go the FI way...
Old Feb 10, 2005 | 09:31 AM
91civicEX's Avatar
Default Re: (ssl2k)
i did all the 1.5 hop ups. first converted to mpfi. then mini me. with the mini me, a header, intake , everything else stock i ran a 16.1 in my porky 4 door. if your trying to go fast trust me and swap to a 1.6. its worth the extra power.
DaX
Jul 28, 2018 09:04 AM
davidhs5
Aug 26, 2010 08:49 AM
efjones9
20
Oct 25, 2009 09:35 AM
skate1968
Jul 15, 2006 03:52 PM
SleepersOwn
May 31, 2003 09:08 PM
